Omega Help Area => Omega General Help => Topic started by: Del Boy on 10 February 2008, 23:16:00
Title: Will it be ok if
Post by: Del Boy on 10 February 2008, 23:16:00
I were to put pre-facelift elite spring on my MV6 facelift or are the spring different in anyway aren't the MV6 ones stiffer than elite springs :-?
Title: Re: Will it be ok if
Post by: Markjay on 10 February 2008, 23:39:21
TB should know the answer to this....  :-X
Post by: Del Boy on 11 February 2008, 18:15:30
Hope so
Post by: Tony H on 11 February 2008, 19:48:48
BEWARE!!! the post count reaper may be swinging his cythe very soon :o
Post by: hotel21 on 11 February 2008, 19:55:55
mmmmmmm, tact.   Not seen that for a while, MJ??     ;D
TB swears that height is adjusted via the shocks, not the springs.
I fitted Irmscher 30 mm lowered rear springs on mine with standard MV6 shocks and it dropped noticably.
Probable that if you did the same but in reverse, you may end up with an increase in height.
But there again, perhaps not......   :-/     :D
Post by: TheBoy on 11 February 2008, 20:15:32
MJ/H21 - its the prefacelift I was talking about. Not sure on facelift.
LSG - why would you want to do such a thing?
Post by: Del Boy on 11 February 2008, 20:44:41
One of my springs at the back the top bit snapped off
Post by: TheBoy on 11 February 2008, 21:10:11
Buy a pair of new springs then....
Post by: Del Boy on 11 February 2008, 21:17:03
Would elite spring be ok on the back with MV6 ones on the front.
Post by: Marks DTM Calib on 11 February 2008, 21:27:07
Right......pre-facelift rear springs are all the same.....
Facelift springs for sports chassis are different to standard.
Post by: Albatross on 11 February 2008, 21:28:10
Sorry for the hijack, but could you do the reverse?
i.e. fit MV6 lowered suspension onto a 3.2 Elite (both facelift) and retain the auto-levelling suspension?
Post by: TheBoy on 11 February 2008, 21:32:39
Not easily - the self levelling would keep raising back.
Anyway, try the normal suspension first ;)
Post by: Albatross on 11 February 2008, 21:36:25
OK, OK point taken, I'll try standard 1st  :y. I was assuming that I'd change the springs and shocks; just hypothetically speaking  ::), would that work?
Post by: TheBoy on 11 February 2008, 21:54:08
You'd have to lose the self levelling I think
Post by: Albatross on 11 February 2008, 22:15:58
If that's the case, I wouldn't even consider it TBH. Thanks. N
