Omega Help Area => Omega General Help => Topic started by: al and omega on 17 February 2008, 00:00:28
Title: Air Con
Post by: al and omega on 17 February 2008, 00:00:28
Hi ive had car around 2 years and always the air condtioning system has always worked i'e compressor kicks-in, engine revs slighty higher and all fans turn on, tried a few times the other day turning eco button on/off but compressor just not working nor engine fans or revs change, checked fuses and relays could it be the pump its self? info would be great regards, alex
Title: Re: Air Con
Post by: Ian_D on 17 February 2008, 04:27:24
Could just need regassing mate.
There is a pressure switch on the A/C system, and if its under pressure, it wont allow the compressor to turn on.
HTH
Ian
Title: Re: Air Con
Post by: alank46 on 17 February 2008, 08:20:34
HTH
Ian
That is, you need to get the system re-pressurised at an air con specialist.
Alan
Title: Re: Air Con
Post by: x25xe on 17 February 2008, 10:00:04
Yes, not somewhere like KwickFit who do not have the ability to diagnose faults etc.  Nor will they be able to properly service the system.
Title: Re: Air Con
Post by: Darth Loo-knee on 17 February 2008, 10:15:31
I was told when your car doesn't have any gas in the air con unit it can make the seals perish, so I would get it done sooner rather than later :y
Title: Re: Air Con
Post by: MutantCav on 17 February 2008, 14:21:11
And if all else fails I have a decent aircon compressor pump here from a 3.0 v6
Title: Re: Air Con
Post by: dbug on 17 February 2008, 16:51:47
To check compressor, pull off leccy plug and check power at plug (use meter or bulb to earth).  Note which is live feed pin on compressor, then connect live feed from a 12v battery to this and briefly connect other pin to the earth terminal - you should hear clutch in compressor click over (quite loud).  No noise compressor knackered - this is usual fault with these.  If compressor ok probably requires regassing.
Title: Re: Air Con
Post by: al and omega on 21 February 2008, 17:00:53
thanks for help, got it regassed and all ok...for now! nxt a think is the power steering pump not losing fluid but very noisy is it a straight forward task? many thanx alex :)
