Omega Help Area => Omega General Help => Topic started by: MutantCav on 23 February 2008, 13:30:25
Is there any way to reset the codes using a paperclip once you have done the paperclip check and rectified any faults?
as far as i know,once the faults are rectified the codes will clear automatically after the car has been started approx. 20 times.
That's my understanding too.
Once the fault is fixed the EML will go out, after twenty or so clean starts the codes will be deleted.
Ok thanks :) So just gotta sort the codes then and hopefully this will sort out the rough running :)
