Omega Help Area => Omega General Help => Topic started by: alexandjen on 23 February 2008, 20:09:31
After washing the Mig today I thought I would use some tyre shine which I bought months ago.
Came up nice and shiny and while I was doing it I noticed and noted the following about my set of tyres:
Front
N/S - Avon ZV3 - 215/55 R16 97H
O/S - Goodyear Eagle NCT 5 - 215/55 R16 93V
Rear
N/S and O/S - Prima Tigar - 225/55 R16 95V
Questions
1) Would the different makes and speed ratings of the front tyres affect the steering/handling as it does seem to have a mind of its own sometimes.
2) Would it be best to swap both fronts for both rears to get a matching pair on the front?
3) Does it matter that the fronts are 215/55 and the rears are 225/55?
4) Has anyone else had experience with these makes of tyre?
Any help would be appreciated and thanks in advance :y
In my opinion
1 yes if im right the nsf is a rotational tyre and the os isn't. i would also get rid of both of the fronts as they arnt the correct size and the ns is the wrong speed rating(can invalidate insurance).
2 no as if your are running different size tyres you should always have the largest on the rear.
3 depends some cars are ok with differnt sizes others dont like it. again might invalidate your insurance.
4 cant help you as never run on any of them.
hope this helps.
lee
I agree with lee,I like to have same name ,size & speed rating on each axle so if you have to or like to switch end to end you can.
In my opinion
hope this helps.
lee
Thanks Lee, I couldn't see any direction arrow on the front tyres but both the rears are directional and are the right way round.
So basically get two new front tyres (225/55) to match the rears?
Any suggestions on a decent budget tyre?
Edit: Should I get speed rating 95V to match the rears?
So to take it from there....
I would definately be swapping the front 2 as they are the incorrect size for the vehicle. As lee said, the speed rating is also incorrect.
On a personal note, I am a stickler to be honest when it comes to tyres. I don't mind spending a little more given that 'your life rides on those tyres' and 'it's your only point of contact with the road'!
.....therefore, i'd see if a tyre shop will do a good deal on a full set of 4 tyres, put 2 on the front (they hardly wear at all) and store the other two new tyres in your garage ready for when the backs wear out.
In my opinion
hope this helps.
lee
i cant really recomend a budget tyre as i allways try to run michelins.
I would also check what speed rating should be on there as mine has w rated all round and i think that is standard fitment (someone will confirm).
Can also concur michelins wear the best so personally think they're worth a little extra.
V rating I think is standard fit for a 2.2 but I notice A&J also have a c*r*v*n ::) so maybe worth a higher rated tyre?
Thanks both :y Lee what Michelins do you use and do you get any tramlining/wandering?
Can anyone explain the speed rating codes to me and advise which I should be running on?
http://www.tyres-online.co.uk/tech.asp
You don't have to whisper the word ;D
What code is a higher rating? :-/
Hi,
I had a mish mash of all sorts on my pre sadly neglected motor. There were not two the same make or size, but strangely enough steering was fine.
As Davlad says, tyres are your only contact with the road.
I bit the bullet and went for full set Michelin Primacy HP, you need W rating.
Ther'e not cheap, but give me peace of mind.
Roger
Try
www.mytyres.co.uk
I just bought some Kuhmo spt ku13 tyres for my mv6 and am well pleased with them the quality is as good as most premium tyres and for your size they are £57.30 each to your door.
Excellent thanks :y
Michelin Pilot Primacy & Michelin Primacy HP. Straight as a die, grip well and nice and quiet.
If you want to spend less, I suppose the Pirellis are good value for money. Alot of the guys use Goodyear Eagle F1's also.
Had some VX fitted 'Kleber' branded tyres that wore out fast, Dunlop SP9000s used, grippy but also didn't wear fantastic.
i run on Michelin Primacy hp and i have no problems at all. w z and y are all higher speed ratings i think the michelins are only available in w but im not 100%
You do if you value you post count ;) :-X
I fitted cheap accelera 225zr16 to rear with dunlops on the front. car wandered alarmingly at times like badly located live axle.
Dunlops wore out inner edge after 20k, also replaced with accelera £95per pair + vat fitted. Car now tracks perfect.
....... you need W rating..........
You need W rated tyres but alexandjen 'only' has a 2.2 & doesn't need such a high rated tyre.
Curiously the lads in the USA only have V rated tyres cos apparently they don't drive as fast as we do in Europe (so says Michelin).
you do if you want michelin as they dont do them in a v iirc
Big_Roger has a 3.2 car which require W rating. V's aren't fast enough .... if we're going by the book.
Check this out:
http://www.event-tyres.co.uk/quotation/filteredresults.php
They supply,fit,balance and replace valve.
Come to a place of your choosing whether it be at home or work and all for 486.70 for a set of four Michelin - 225/55 R16 [95W] - Pilot Primacy HP.
This sounds good to me :y
Edit: £ 428.68 for a set of Pirelli P7's
Ive only got a 2.0 but ive got w rated on mine as i find that the higher speed rated tyres last longer as well as grip better than the lower ones
Check this out:
do a search through other posts as im sure there was someone who had a lot of problems with the p7s
That's OK. You can go faster if you want, but I DON'T think it's a good idea to go slower - like various Senators you see on the Bay of e.
Try
www.mytyres.co.uk
Are these the ones you got?
Kumho - 225/55 R16 [99W] - KU31 £ 86.90
2 x Tyres = £ 173.80
3 x Tyres = £ 260.70
4 x Tyres = £ 330.22
This Kumho tyre has a speed rating of "W". This gives this tyre a maximum speed of 168 MPH
Try
www.mytyres.co.uk
Yes thats them and they are only £57.30 each from my tyres. You will have to get them fitted on top but that won't be anymore than £10 each.
I also have some race compound Kuhmo's on my 400bhp cosworth so I can confirm the quality and grip are superb.
Mix tyres at your own risk - three different brands on this car
(http://i91.photobucket.com/albums/k286/martinimber/ro.jpg)
Many years ago when I was a poor apprentice .... I had two completely different types of tyre - same size - on the front of my Cortina MK III. It pulled heavily to the kerb, tracking etc made no difference. Two matching tyres on the front, and it was sorted.
Mine does this most of the time and wanders about now and again especially when hitting bumps and ruts.
I think once you get 2 new tyres on the front your problems will be fixed.
:y Think I might get 4 of those Kumho KU31 225/55 R16 99W XL BSW
from Mytyres :y
I don't think you'll be disappointed mine were delivered within 3 days of ordering.
You are definitely on dodgy ground with your insurance company with the odd sizes and your insurance will not be valid with the H rated tyre.
Tyres are one of the first things they will check in the event of an accident, even if it's not your fault.
- your car handbook should indicate what size and rating of tyres is specced for your car. It differs according to age of car (certainly pre/post facelift) and engine. My 2.5 requires V rated so unlikely you need W on your 2.2 - but check the book.
- I concur with all the comments about compromising insurance (or worse) if using the wrong size/rating. Not worth it.
- I think Michelins are over rated/priced. On my 98 2.5CDX I have 4 Falkens that I paid £60 a corner for fitted last year. If you want a more premium make I would go for Continental but these are likely over £100 each. I have also used Kumho in the past which have been fine - I got 30k off a set on my 2.0 estate.
Cheers
Ian
Thanks for your comments Ian
No probs!
Of course you will get as many opinions as answers on tyres ;)
Check this out:
this sounds like a lot of money to me :-/
(not for Primacy HP's but in general)
