Omega Help Area => Omega General Help => Topic started by: dbug on 02 March 2008, 16:42:01
Is this ok for use on Crank on V6?
http://cgi.ebay.co.uk/DRAPER-27MM-X-30MM-EXPERT-TORQ-DEEP-OFFSET-RING-SPANNER_W0QQitemZ270194879568QQihZ017QQcategoryZ30917QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
Thanx
Crank bolt on the V6 is a Torx headed bolt :-/
E20 Torx
Thanx
Do you mean for when you do your cam belt? If so yes, it will hold the eccentric for you.
Thanx
Yes - to adjust position of tensioner pulley.
Sorry my post wasn't clear - knew crank bolt was E20 torx.
Thanx all
It should be fine for the idler adjustments
This is the one I have:
http://cgi.ebay.co.uk/DRAPER-54302-30mm-HI-TORQ-COMBINATION-SPANNER_W0QQitemZ300199730095QQihZ020QQcategoryZ30917QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
