Omega Help Area => Omega General Help => Topic started by: shaftt24 on 05 March 2008, 00:54:55
hy
i have opel omega from 2001 2,2 dth
and my question is how to take down the dashboard..because about 2 weak i have strange noise over the board...when i turn the heat on!
that noise like 'zszszs''..:D
please help me
thanxs :(
Sorry, what is the board?
on board-car board...sorry for my eng ;)
Dashboard?
yes...yes..sorry..i mean dashboard
heater fan? :-/
i have heat on my car..its works,,,but when i turn on..i have some strange noise..is coming from dashboard..'ssss'
what i want..is a topic with turtorial...i want to take down the dashboard..to clean the airflanels
Think he means the center console?
Sounds like it may just me the noise the actuator make when redirecting air, can you produce it on demand by pressing the feet / centre / windscreen buttons?
or press and hold auto & off for 10 seconds to reset the servos...is it the same noise?
the sound i have al over the left and right...al over the dashboard..but only whet the heat is on.when i use the AC..i dont have that noise..so i think the air supape is dont close from COOL-HEAT!:(
i want to take down the dashboard to se what is the problem but i dont no how..
-also i have duble climattronic sistem..and is a litle complicate.... ::)
-also the heat dont come with power..its slowly..
These may help if i read post correctly
http://www.omegaowners.com/forum/YaBB.pl?num=1152618876
http://www.omegaowners.com/forum/YaBB.pl?num=1152745540
tnxs..very much.. :D
but how i get the airflenels i need to clean it..i dont want to change anithing on MID/TID/GID/CID..i want only to clean the airrepartitors :-[
try this for starters - its very quick and may sort the problem out.
At least it will reset the climate system to how it should be.
ok..but to reset i need to torn on the car?or no...
i wil try and i wil comebak thankx a lot ::)
im back
now i reset the servos presin/hold auto-off...but i have still that noise..
-about 4 weks ago i change the termostat beacuse the yearly term is dont close..so i change it :(
-now i have that strange noise on the dashboard and when i put the heat on 25C its heat slowly...wery slowly..
-afther the reset presing and holding auto-off..i put the heat on 25c...and first i havet cold...and afther 1-2 minute i have heat but wrealy slow. :(.
