Omega Help Area => Omega General Help => Topic started by: f13platform on 14 March 2008, 17:18:57
i did that today with one man kit
everything is done by order in right way
and there is no air in system
break work fine a littel stronger than b4 :-?
and when i break it feel softer than b4
is that normall??????
thank you
(NO ABS Light)
blimey you had a lot of breaks when doing your brakes ;) ;D
How soft does it go, is there a lot more travel in the pedal? (go down further)
yeah it go down a bit more than b4
and it go smooth
Sorry, I don't understand the question/issue?
after changed the break fluid
or it s air?
blimey you had a lot of breaks when doing your brakes ;) ; .....
Seams the kettle is calling ........ ;D :y
or it s air?
Same happened to me. Turned out I had a bit of air in NSF...
