Omega Help Area => Omega General Help => Topic started by: philhoward on 15 March 2008, 07:47:08
Title: LPG wiring..
Post by: philhoward on 15 March 2008, 07:47:08
Morning all...
Just bought an N reg 2.0 16v and about to put LPG on it, but its the first cat'd one with lambda i've done - hence the system needs a few more wires connecting.  Until my manual drops through the door, can anyone advise on where I can find the following info?
Best place to pick up the tach/rpm feed and lambda sensor  signal(accessible connector somewhere?) - the lambda sensor needs splicing as the system also sends back the emulated figure back to the ECU
Warm up time of the lambda sensor (its listed in minutes in the software?!)
The rest i can figure out with my meter - but after reading a post regarding the "bridge" to pickup the water feed (or is this just V6s?) - is it obvious where it is, or hiding under something?
Cheers,
Phil
Title: Re: LPG wiring..
Post by: TheBoy on 15 March 2008, 08:16:55
ECU has an rpm signal - probably 'cleaner' than the direct crank sensor feed.
Not sure about lamda sensor on a 2.0l
Coolant bridge only on v6.
Post by: Martin_1962 on 15 March 2008, 08:37:05
The green wire off the ECU for RPM,
