Omega Help Area => Omega General Help => Topic started by: 106rallye on 15 March 2008, 15:22:31
Hey guys.
Im in the middle of changing the dis pack and for the life of me i cant get the dam thing out! everthing is off it but i cant find a hold big enough for it to fit through and get the new one in, tried both the top and the bottom. help please :'(
I take it the scuttle is off??
You might have to remove plenum.... very quick just use a bit of oil on the O rings when replacing
naa cant remove scuttle, the wipers are seized on and i dont have a puller
so were mine when I first tried. Put a squirt of wd40 in the wiper bolt area tap it lightly with a small hammer and then just wriggle it like f%$£, particularly in and out toward the windscreen and out and it will come off.
The car is doing my head in! got everytthing back together, leads on the same way, but when i try to start it its as though they are on wrong! im ready to burn this thing!
Just double check passenger bank leads - the order is odd on the DIS...
ive double and triple checked it against what i have wrote down (which im starting to think must be wrong)
Does anyone know if this is right?
(http://img134.imageshack.us/img134/8913/engineanddisnr8.png)
they numbers arnt the firing order, just what i numbered the leads when i was doing the rocker gaskets
That looks wrong to me...
Cylinder order is
BACK
6
5
4
3
2
1
FRONT
Still looking for DIS order, from memory its
1 3 5
2 6 4
but hopefully someone can confirm the DIS bit first
1 3 5
2 6 4
Mine is (from a note I made when I changed mine)
4 6 2 p
l
u
1 3 5 g
1 3 5
2 6 4
4 6 2 p
l
u
1 3 5 g
Yours sounds correct :y
1 3 5
2 6 4
4 6 2 p
l
u
1 3 5 g
right now im really confused, i changed it to that and its not starting at all, before it would run really rough for a few secs then die, now as soon as it catches its dying :'( its to dark now so will have to look at it again tomorrow but i have no idea whats wrong
ok ive checked every single thing 3 or 4 times, everything is in the right order, nothing else is unplugged, tried it with new HT leads and nothing. and to top it all off i think the started as packed in!
only thing i can think of is the park that im trying to fix is damaged, can anyone think of anything else?
Is that order correct for the older 95 dis packs?? Only the connector is on the top on the older ones not at the side?? Are the older dispacks different??
anyone?
