Omega Help Area => Omega General Help => Topic started by: caolan_p on 22 March 2008, 16:46:46
Title: crank shaft sensor
Post by: caolan_p on 22 March 2008, 16:46:46
hello all ,would it be bad on the car if i disconect the crankshaft at the oil filter to see if its causing the prob,as i cant det the codes read till after easter and its putting my head away  :'(. and hope you all have a nice time over easter  :y
Title: Re: cam shaft sensor
Post by: Dazzler on 22 March 2008, 17:58:45
hello all ,would it be bad on the car if i disconect the camshaft at the oil filter to see if its causing the prob,as i cant det the codes read till after easter and its putting my head away  :'(. and hope you all have a nice time over easter  :y
Do you not mean crankshaft sensor :-/
If you disconnect this it wont run much at all......
Title: Re: crank shaft sensor
Post by: caolan_p on 22 March 2008, 18:10:14
sorry yes ,crankshaft sensor
Post by: Marks DTM Calib on 22 March 2008, 18:17:52
2.2 might run actually....
Post by: TheBoy on 22 March 2008, 19:18:26
2.2 will run without crankshaft sensor, its a bugger to start though.
Post by: caolan_p on 22 March 2008, 19:55:43
thanks for the info lads ,have a nice weekend  :y
