Omega Help Area => Omega General Help => Topic started by: Bacon Butty Man on 24 March 2008, 16:54:28
Title: Paper clip test a little confused
Post by: Bacon Butty Man on 24 March 2008, 16:54:28
just done the test and one by one all the lights went out exept the engine electronics immobilisor sign was flashing like this - --    - --    - --    - --, i cant see where i get a number from to find the fauilt code,  :-/
the ONLY time this light is on normally is when the ignition goes thru the start up etc, then its never seen again so to speak
Title: Re: Paper clip test a little confused
Post by: albitz on 24 March 2008, 17:02:28
its a bit like morse code,1 flash =1, 2quick flashes =2 etc; each code will repeat 3 times.the start of the test will be code 12 ,1 flash followed by 2 quick flashes,this will repeat 3 times.then if you have,for example a code 19 stored it will flash once followed by 9 flashes in quick succession this will also repeat 3 times at the end of the test code 12 will repeat 3 times to let you know that it has finished . hope that helps explain it :y
Post by: Bacon Butty Man on 24 March 2008, 17:19:17
so if it just flashes code 12, that means that the only fault is code 12 but ther doesnt seem to be a code 12 on the list :-/
Post by: Mike Collins on 24 March 2008, 17:21:25
12 is not an error, it denotes the start and end of the test.
Post by: Bacon Butty Man on 24 March 2008, 17:32:28
ergo no faults  :) :)
Post by: TheBoy on 24 March 2008, 19:22:07
No faults :y
Post by: Bacon Butty Man on 24 March 2008, 20:03:58
god i love this site, how much would it have cost me to find that out at vauxhall, the best part of 100 quid i rekon
