Omega Help Area => Omega General Help => Topic started by: Squatch on 01 April 2008, 13:14:32
With the warmer weather have been driving with windows down and noticed metallic clicking sound from exhaust - it gets louder under acceleration and disappears when idling. have an occasionally noisy lifter - could it have anything to do with it? Cheers!
possibly heat shields come loose :-/
Manifold gasket leaking?
I have the same noise and have been told its the manifold gasket for definite. Not sure how much work is involved though! :'(
Sure does sound like a leak to me :-/
Thank you all for info - I suspected the manifold might be the culprit...is it a tricky fix?
If your lucky it will be the drivers side which is a PITA if its the passenger side :'(
Thanks again - if it's fine this weekend I'll get the spanners out...
