Omega Help Area => Omega General Help => Topic started by: bighed on 09 April 2008, 18:07:34
Are these spark plugs any good for the V6??
nope bloody rubbish would not put them in a lawnmower mate >:( >:(
What u recommend? Cant get anythin off ebay as doing my cam cover gaskets has been bought forward to this saturday (was the one after)
genuine vauxhall mate about the best you can get and not too expensive :y
Think i was told £4 each. bosch any good??
I use NGK twin electrode and they are fine - 4 electrode are bad for LPG
i had them in my mv6 and the electrode cracked and fell into combustion chamber and bent two inlet valves so will never use them again >:( crock of sh!te
I speak as I find. I fitted a set of 6 NGK Iridium plugs after suffering a high load misfire, which a new set of GM plugs didn't cure. The NGK's have been in for over 20k, still give an excelent smooth response, worth ever penny. :y
regards
richard a
Interestingly I have been advised to install NGK BKR6EQUP plugs gapped to 30 thou prior to the LPG conversion. This is by the converting company.... :)
Have to say I am not a fan of NGK plugs in cars, maybe they do varying qualities I don't no.
But all my experiences have been bad when fitted to cars, especially in winter.
On the flip side, they are brilliant in my bike.
Mike
Used NGK on all my bikes and also on the Sunbeam
I use 4 electrode model (NGK)..and idle is very smooth dont have any problem..(a bit expensive than standard vx/opel)
