Omega Help Area => Omega General Help => Topic started by: Marie on 10 April 2008, 17:35:46
Right ok so i need a replacement for the following reasons:
1: the securing bung has split into 2.
2: the retaining clip no longer works at the throttle end so i wirelocked it.
Is this an easy job?
the hanyes manual states that there are electrics connected to it for my auto box but VX say no...... if their is are they plug and play?
VX has quoted £60 then add the vat. :'( :'(
I noticed a switch under the scuttle just by the bulkhead. Kickdown for the auto. Gearbox I guess.
Oh, and the LPG injectors might be in the way. What muppet mounted them there? ::)
LOL i wonder who that was?????
i have small hands i can get round it and in no snags.
I was just tryin to search else where for a cable £60 is a bit steep. but hey i might have to bite the bullet yet again.
Wouldn`t one of the lads whom break Omega`s here on O.O.F be able to send a 'good' cheap throttle-cable Marie?
`Sure it`d be a lot less than £60! :y
Thats what i was kinda hoping but nobody is breakin a 2tlr auto
Hi
Can't you adapt a bicycle brake cable to fit, that's got to be cheaper than £60.
Alan
Hi
Alan
i dont quite think that will work and if it did how safe would it be? not very i dont think.
Is an auto's different from a manual's. If one of the Omegas in the scrappies near me is suitable I could send No 1 son down with it, but he doesn't have to be 'back on board' till a week on Sunday.
Cables for a manual don't have the kickdown switch.
Also, its a very easy job to replace, as I found out with mine at the cambelt partay ;)
I know a manual doesn't but I'm not so sure that an auto does either. The kick-down switch on my Senator was actually under the accelerator pedal & obviously an Omega's isn't. I'd have thought the throttle positioner acted as the kick down switch.
Could you see if they have got one from a 2ltr 16v auto please andy and how much and then we can go from there. If they haveone at the right price it can wait until your sons back.
its under the scuttle so kevin told me.
Will do. I'll have a look over the week end (in between hanging wall paper :-?)
Acted on by another cable? Or does the cable 'pass through' the kick down switch?
not sure........
kevin might know
looks like this. not 100% sure
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380012004649&mpt=1207852440891&tGUID=0e50835e1180a0e20277b8a7ffcc4322
Part of the cable itself, moulded in place.
not sure........
kevin might know
Thats the one :)
Check the part number tho, I know the 3ltr one I have fitted to my 2.5 is about 5" longer, so it tucks under the scuttle at the rear. Not sure if the 2ltr is any longer or shorter...
Hi Marie,if you ring this number and speak to either Henry or Rupert they are the people who run the scrappers called las-jacarandas they might have another omega like yours there with a cable on it.. I have dealt with them before and they are very good. The number is 07706495877.
thats the one you want marie on the ebay link ! if the 2.5/3.0 are the same i have one £10 posted :y
Cheers fellas ill ring VX tomorrow and get a part number to find out whether the 2 ltr and the 2.5/30ltr are the same part numbers.
thankyou achoo81 ill give them a bell
it is ok to fit a second hand one? alsong as its ok surely.
first time i have heard of one going faulty so would say yes ! :y
it looks like the end of its has been butchered. (not by me i might add)
i reckon it was done when the bl00dy idoit who fix my car when the cambelt snapped tried to get the retainin clip out.
yep easy done if you dont know what you are doing ! ;D
i could re wire lock it on better but i might as well replace it as the rubber bung thing it tits too:(
Which all goes to show how much notice I've ever taken of this car! ::)
Two different cables for yours dependant on chassis number which are a different cable to the 2.5/3 cable.
CABLE, ASSY., ACCELERATOR, RHD (IDENT LP) (USED WITH AUTOMATIC TRANSMISSION) 20SE, X20SE, X20XEV -V1999999 90448678
CABLE, ASSY., ACCELERATOR, RHD (IDENT AX) (USED WITH AUTOMATIC TRANSMISSION) 20SE, X20SE, X20XEV W1000001- 90572517
The V & W numbers relate to the chassis number.
Why can't Vx do owt simple
So i need the casis number. to find out which part i need.
arse looks like i might have to pay £60.:(
Your chassis number is on your logbook or you can see it in the lower passenger side of the windscreen. Should look something like this W0L0VBF69W1244216.
Try looking on ebay for the part number.
