Omega Help Area => Omega General Help => Topic started by: psg150 on 10 April 2008, 01:24:51
My garage is going to fit one for me - what should I be being charged?
About 80 quid for the part and an hours work tops.....
Vx retail price for the item is about 130+Vat but, you can get them from the factors (still Bosch made) for much less than that
What ^ he says - £80 off vauxhall parts warehouse or similar on ebay anf fit it yourself.. :y
I got one for my 2.2 last week for £62 and took 2min to fit it ,i dont know if they are the same for yours ?
Ta guys - is it a simple job? is there a guide to it anywhere?
Pretty sure there's a guide in the 'How To' section :y
Here you go psg150..
http://www.omegaowners.com/forum/YaBB.pl?num=1155224533
Bruce
If only! ;) It takes you longer than that to put the plasters on afterwards with a V6! ;D ;D
just seen the how2 for the V6,oooooooooooooo no thank you glad mine is a 2.2 ;D ;D
2.2 is coil per plug, so ecotec cover off, then 2 torx bolts, and its out. dead easy.
2.6/3.2 is similar, just more junk on top.
2.5/3.0 are the fun ones, with the DIS mounted on the back of the engine. I replaced one, i was sat on a plank of wood going across the engine bay
