Omega Help Area => Omega General Help => Topic started by: Alanb on 11 April 2008, 12:51:18
Title: Glovebox/Airbag
Post by: Alanb on 11 April 2008, 12:51:18
Hi Guys & Gals
Anybody know how to remove airbag covering on passenger side of a 96 Omega so as i can change my broken glovebox?
Th 8-)anks
Title: Re: Glovebox/Airbag
Post by: 106rallye on 11 April 2008, 12:58:26
you need to remove the airvent next to it, cant remember what else  ::) if you have a haynes manual its all covered in that  :y
Post by: MutantCav on 11 April 2008, 13:04:02
You can remove glovebox without removing the airbag cover...in fact I'm pretty sure I'm right in saying you need to remove the glovebox in order to get to the star bolts holding the cover in place!!
Post by: TheBoy on 11 April 2008, 14:08:46
just need to remove the bolts to airbag
Post by: Robin Hood on 11 April 2008, 16:16:41
Just done my mini face lift and if yours is similar – remove the three bolts (torx) in the roof of the clove box and then lift the front of the air bag cover a couple if inches.  Underneath, at the two front corners is a screw (+ve) that needs to be removed and two more inside the glove box, one either side.  For the final one, remove the side vent cover and top screw (+ve) and the air vent it retains.  Once the air vent is out the last screw (+ve) becomes accessible.
Post by: Andy B on 11 April 2008, 17:16:25
According to Mr Haynes this screw isn't there!  :-? It took me a while to find it on my mini face lift (+ Araldite to repair what I'd broken trying to find it ..  :-[ )
