Omega Help Area => Omega General Help => Topic started by: Dazzler on 15 April 2008, 15:22:38
Title: Re: front doors ...
Post by: Dazzler on 15 April 2008, 15:22:38
Have you checked that the 2 bolts holding that arm assy on the door are tight???
Get a good 2nd hand one on here, not to bad a job to replace or remove old one if not broken and give it a good clean and regrease and job done :y
Post by: f13platform on 15 April 2008, 15:37:16
rain rain lol
but i ll have a look .
if it s broken? i just have to take it out and change it?
Post by: Dazzler on 15 April 2008, 15:39:39
Yep,
Also check that the door frame is not cracked, if it is then you will have to fit reinforcing plates as well, not hard and not expensive, have a look in the maintenance guides for a how to ;)
Post by: f13platform on 15 April 2008, 15:54:03
thank u
Post by: f13platform on 15 April 2008, 17:05:11
i looked it s broken
the arm holder is broken
what i have too do?
Post by: Dazzler on 15 April 2008, 17:08:46
Get another catch assy.
Ask in the wanted section, chances are Chris or MarkieMark will have a good one or you can by new from Vx about £30ish i think.
Post by: f13platform on 15 April 2008, 17:42:50
i wouldnt do that. spend money in wrong desing
they put something so cheap and weak in very heavy door
i opened that bolt and leave it
the handel went inside so much the better  and no more noise
it got 2 suport .
