Omega Help Area => Omega General Help => Topic started by: FRE07962128 on 17 April 2008, 12:56:35
Title: DASHBOARD POWER FAILURE
Post by: FRE07962128 on 17 April 2008, 12:56:35
I am a desperate damsel in distress, so can someone help me please?
I removed the dashboard on my Omega to replace a light bulb.  Refitted it but now none of the clocks work, the central consul is dead, and only the indicators on the dashboard are working along with the temp. fuel, & handbrake warning lights flashing!  I have refitted the dashboard four times, checking the terminals, but still no joy!
What have I done wrong please?
A tearful Lizzie Zoom  :'( :'( :'( :'( :'(
Title: Re: DASHBOARD POWER FAILURE
Post by: albitz on 17 April 2008, 13:36:26
sounds like something hasnt been plugged back in. :-/
Post by: Jimbob on 17 April 2008, 14:09:24
Ive done similar myself today,
Dash out to change 3 illumination bulbs (only 1 gone)
Put it back together, and no lights!
Took it apart, reseated bulbs, put it back together, all happy.
You have pushed the dash far enough back home havent you?
Post by: Marks DTM Calib on 17 April 2008, 14:10:09
1) makes sure the instrument panel is fully home
2) Check the fuses (cant remember which but F14 or 15 rings a bell)
Post by: f13platform on 17 April 2008, 14:15:49
u have to push it back and put the bolt back on
than try it ...
i hope u didnt damge that  bule paper in back of the speedo meter
make sure the blub holder are in right place
they conect with the blue paepar :y
Post by: rickyboy on 17 April 2008, 15:06:50
Just changed the fuse an hour ago.  As Mark said F15 will make the dash lights go out, so check it hasn't blown.  I suspect the clocks aren't fully home.   :y
Post by: FRE07962128 on 17 April 2008, 19:21:37
Thanks all!
I have discovered a fuse that covers all the dash and consul had blown!  All ok now.  A very relieved Lizzie Zoom :D :D :D :D :y :y
