Omega Help Area => Omega General Help => Topic started by: JezInBrum on 17 April 2008, 18:26:31
Title: V6 Radiator
Post by: JezInBrum on 17 April 2008, 18:26:31
Hi, quick question for you all. Would a radiator from a 2001 2.6 auto with A/C fit a 1996 3.0 auto with A/C?
Thanks in advance, Jez
Title: Re: V6 Radiator
Post by: MutantCav on 17 April 2008, 18:49:17
If not I have a 3.0 one here from a 98 elite with aircon that most definitely will mate...
Post by: Andy B on 17 April 2008, 18:52:25
H21has/had a new one! 2nd hand is a bit of an unknown!
Post by: Kevin Wood on 17 April 2008, 18:57:34
Don't know about the 2.6 but my 3.2 has a separate gearbox cooler whereas earlier cars had it built into the radiator. Might be worth checking. :y
Post by: Pete Elite on 17 April 2008, 20:06:54
  EPC quotes different part #s so i would say not :(.
Post by: markey mark on 17 April 2008, 20:08:27
no mate facelifts had seperate oil coolers for gearbox ! pre face lift it was built in ! :y
Post by: MutantCav on 17 April 2008, 20:14:54
I guess you take a risk with second hand parts, but the one I have would be out of a still running nicely 3.0 v6 98 elite...
Post by: JezInBrum on 17 April 2008, 20:32:41
Thanks for all your replies. I was having a magpie moment & stumbled across a new unused one so was toying with adding to my hoarded parts collection.  :-X
btw its listed on fleabay Item number: 300215946808
Post by: Mike Collins on 17 April 2008, 21:16:28
My 2.6 has a separate air/fluid heat exchanger for the transmission. Sits between the radiator and the condenser.
Post by: Kevin Wood on 17 April 2008, 22:40:22
Sounds the same as my 3.2.
I guess an older radiator might work in a newer car - just don't connect the cooler, but not the other way round.
