		Omega Help Area => Omega General Help => Topic started by: mykd2007 on 22 April 2008, 18:56:31
				I have a 3.0 v6 estate which has recently had a new coil pack, genuine gm leads and bosch 4 prong spark plugs. It ran fine until 2 days ago. It now sounds like it's missing on 2 spark plugs, and drives like a pig! It is just about bearable on very very light throttle (cruising on a level road). If I boot it (which is rare, as it  feels horrible), it accelerates up to 3500- 4500 rpm, and holds there for about 5 seconds, and then lets it go all the way to the redline. Any guesses???
 Thanks,
 Myk
				have you tried the paperclip test for fault codes ?
				no, not yet, but there isnt any engine warning light. I will check later
				there wont necessarily be EML illumination due to a mis fire..
 In my experience I have still to see one that does come on with mis fire...
 Were the breathers cleaned as the dispack etc was done and have you retraced your steps to ensure everything is still secure?
 Also are cam covers free of water / oil ?
				First question that springs to mind is does it occur on petrol, lpg or both?
 Second is when was the petrol and LPG filters last changed?
				What was the reason for you changing the plugs, leads and dis?
 only reason i ask is that before i bought my omega, my mate who owned it before me had the dis pack replaced twice then it went again.
 Turned out to be a faulty HBV (heater bypass valve) which was leaking water straight onto the dis (great design mr VX  :y). once this was changed (£30 part) and the dis again, the problem has never came back.
				Hi, I have just paperclipped it. It came up with 19. I changed the bits, due to the leads being crap copies which fell apart on the last plug change(champion I think), the plugs needed doing (as the LPG seems to eat plugs every 6000 miles). I have moved the coil pack. I custom made brackets for it. It sits near the water expansion bottle. I have checked the low tension side with a multilmeter. It has got an oil leak on 1&3 from the rocker box gasket. I have removed the excess oil, used carb cleaner on the insides of the leads, changed the spark plugs on 1 and 3. The problem is the same on petrol and lpg (slightly worse on LPG, but not much).
 Cheers,
 Myk
				forgot to add... no water leaks, and the breathers are clear (first thing I did when I got it). petrol and LPG filters done 5000 miles ago
				Crank sensor is knackered
				I only changed it 10000 miles ago....and I rerouted the cable away from the exhaust.
 Genuine or non-genuine?
 matters not ... 19 is crank sensor fault ....  :(
				ok, many thanks for all your help. I will get another one ordered now. The one on it is a genuine vx unit. It was replaced last time because there was no spark/injection on LPG or petrol, but that was code 31 (I think)
				31 is "no rpm signal" which is normal with the engine not running ......  :)
				As above...31 will come up if the engine is not running...if you had the crank sensor changed because it was checked with the engine off...then you wasted your money most likely...but 19 is crank sensor knackered, end of...
				I may have been wrong with the 31. changing the sensor cured the problem, as it ran properly....before it wouldn't start at all.
