Omega Help Area => Omega General Help => Topic started by: mccarthy on 07 May 2008, 21:57:01
Title: locked out
Post by: mccarthy on 07 May 2008, 21:57:01
Can anyone tell me how to get into my car as the battery is flat and I can`t use the remte and the key won`t open the door
Title: Re: locked out
Post by: Mike Collins on 07 May 2008, 22:06:16
You have to apply a worrying amount of force to the key.
Happened to me a couple of years ago, AA man was braver than me, but then it wasn't his car or key.
He did unlock it though.
Post by: RobWheatley on 07 May 2008, 22:07:53
From other post's you have to crawl underneath and put jump leads on the starter terminal.
Good luck.
Rob
Post by: CaptainZok on 07 May 2008, 22:14:52
key in drivers doorlock and turn clockwise, needs more force than usual but it will unlock.
Note that the internal button won't come up but the door will open anyway.
Post by: mccarthy on 08 May 2008, 06:28:10
Thanks boys I`ll try that soon and let you know.
Post by: Mr Skrunts on 08 May 2008, 07:42:15
Does it have a towbar and electrics socket on it?
Post by: Mr Skrunts on 08 May 2008, 07:47:25
(http://i278.photobucket.com/albums/kk106/skruntie/7pintrailer.jpg)
(http://i278.photobucket.com/albums/kk106/skruntie/6pintrailer.jpg)
Post by: Mr Skrunts on 08 May 2008, 07:51:59
Identify the 12V according to the socket on the vechicle end, attach the negative from a jump lead/battery to the trailer tow ball frame.  Push in a live wire with an inline fuse fitted, and if I am right then click the remote control and entry is gained.
That of course is if the  12v is a permanent live, I am sure others will confirm the details on the forum.
Post by: mccarthy on 08 May 2008, 09:00:28
Great news , it worked, thanks very much ! one relieved owner.What a great site.
MUngogerry.Alias mccarthy , now how do I change that.
Post by: Mr Skrunts on 08 May 2008, 09:03:12
What/how did you actually manage it?
Go to User CP and edit your profile regards your Alias.
Post by: mccarthy on 08 May 2008, 20:17:46
I turned the key that little bit more and it worked, all the codes were still there as well.
thanks again,
Mungo
