Omega Help Area => Omega General Help => Topic started by: macca on 01 May 2008, 14:22:53
I've started to notice a loose knocking sound from wheel arch area. I'm suspecting worn droplinks. Is there anyway of checking them before I go ahead and get some new links fitted? :-?
BTW: Doesnt seem to have any effect on steering or handling but then I hardly thrash about in it anyway. :P
cheers
mark
Its more of a light knock which tends to dissapear/lessen when cornering.....when bad you can get them to knock by bouncing the relevant corner of the car.
Droplinks start to knock through wear long before it's easy to detect any real movement in them. They're cheap enough to replace, and although pattern ones are allegedly not as good as original, I use them
and get enough wear from them to make it worthwhile.
It's not particularly an urgent safety issue, but getting rid of the annoyance is magic. Takes about 20/30 mins per side, (except for the whizz-kids), given no snags removing bolts.
Quick, free way to check remove them and take a short, careful drive.
What sort of cost are they I think mine need doing
About 20 quid a pair for FAI ones......beware the super cheap ones, they dont last!
:-[ what does FAI mean please
Lol, they are a manufacturer of drop links, see here:
http://cgi.ebay.co.uk/Vauxhall-Omega-Stabiliser-Anti-Roll-Bar-Link-Rod-SS506_W0QQitemZ380017669935QQihZ025QQcategoryZ10404QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
:) Thanks for that , are they avalible on trade card at vx do you know I suppose its worth changing the pair in one go as it suspension bits , is that a faily good price do you reckon considering its got the postage added to it :question
Its an excellent price, the Vx ones are much more even on trade club prices and are not a lot better!
Feel free to pop round if you want a hand...
I may pop over to you soon if thats ok I have something you like ;)
thanks mark, just bought a pair :D.
At that price its worth changing them even if its just to eliminate them as the problem.
Knocking - jack it up, look for suspension play (wishbone bushes, ball joints, upper shock bearing etc), if none found, change droplinks...
just brought a pair too £20 just over inc post well worth it if it stops that clunking ::)
Have had a knocking from mine over the last few months, but not really used the car that much. Managed to get under it yesterday whilst it was up on ramps.
Drivers side droplink is solid not even moving up or down, passenger side has, at a guess, about 2mm of movement in it. Just going to order a pair of droplinks and a driver side wishbone and then all of the front suspension has been replaced in the last 2 years (Shock leaking on one side front and back, spring on oppositre side front for MOT)
Update:-
Using the ebay link in this thread.
Droplink ordered Wed at 7am. Arrived at work (easier for parcel delivery) 10-55 am today.
The links I ordered turned up on Tuesday were fitted yesterday, the old ones actually seemed in pretty good condition though :-? which surpirsed me as a local vx dealer did a free check on the car back in september and had advised one was worn ::) . Any way they have both been changed and I did notice a reduction in the clunking :) but I think the wishbone bushes are starting to go although they were not an issue in March when the car was MOT'D
Got mine yesterday :), fitted them this morning :D.
WOW......feels and drives like a brand new car now. ;D
Best twenty quid I've spent in a long while :y
Droplink fitted, noise all gone and now drives like a different car.
