Omega Help Area => Omega General Help => Topic started by: hotrod222278 on 13 May 2008, 21:57:49
Have just repaired a broken wire on my horn, only to find oil dripping down via the anti-roll bar and intake pipework assey. I traced the problem to the throttle body and breather pipes, I took everything off and checked through making sure the plastic bits are all breathing properly, then tried blowing down the rubber pipes little pipe seem to breath ok, but with one finger over one of the larger pipes, blowing seemed to be a lot harder could it be possibly blocked or is it surposed to have a resistance....??? Please help, rather not kill the oil cooler with too much preasure.
Look at the maintenance guides section and you'll see something all about cleaning out the breathers.
