Omega Help Area => Omega General Help => Topic started by: Machinmacone on 15 May 2008, 15:17:50
Title: Lumpy tickover
Post by: Machinmacone on 15 May 2008, 15:17:50
Hi all
          My 2.0L omega is running a little lumpy on tickover it's not really that bad on petrol but on switching to LPG it becomes quiet pronounced.
          I've just changed throttle body and idle air control valve and checked all vac lines.
          Anyone give me something else to try.
I do have a blow on the exhaust manifold could it be that.
                          Cheers Julian.
Title: Re: Lumpy tickover
Post by: rickyboy on 15 May 2008, 16:19:57
I'd say it's the blow from the exhaust manifold.  Your LPG system really needs the o2 sensor to be giving out the correct readings in order for it to control the mixture.
Post by: Danny on 15 May 2008, 20:00:37
could be running a little too lean at low revs
does the EML occasionally come on when you're doing a steady 30-35 mph and the revs drop to less than 1500?
Post by: Machinmacone on 15 May 2008, 22:11:54
Hi
Thanks for the responses so far no eml lights at all.
                     Cheers Julian
