Omega Help Area => Omega General Help => Topic started by: jemis on 14 May 2008, 10:36:15
Title: My sunroof has a mind of its own, why
Post by: jemis on 14 May 2008, 10:36:15
A few times recently my sunroof half opened in the tilt position whilst driving along and yesterday whilst parked up the alarm went off and when I went to it the sunroof was halfway back.
Is it a faulty switch or something else.
Title: Re: My sunroof has a mind of its own, why
Post by: Andy B on 14 May 2008, 10:40:47
Before you dismantle it all, have you tried resetting it? Have you had the battery off recently?
Push & hold the switch in at, closed/tilt/fully open & hold till all movement stops.
Post by: jemis on 14 May 2008, 14:17:25
Yes I have done that evrytime it has happened.
Post by: Sabs on 14 May 2008, 14:44:39
this forum has got it all, i was just about to post on this topic and bam someone else already has.
im watching this for a result too; i have to jiggle my switch for it to close properly otherwise it decides to tilt open.
Post by: The Barge Captain on 14 May 2008, 22:33:51
I've had one with a dodgy switch.
Post by: jemis on 14 May 2008, 22:38:30
Did it have the same symptons.
Post by: SteveD on 15 May 2008, 09:05:31
Had a dodgy switch on mine with exactly the same symptoms. I used to find turning quickly a few times would fix it for a while. I guess it's the fault of the UK weather - the switch only gets used 2 days a year!
Post by: Richie London on 15 May 2008, 11:00:16
well seems theres a few of us having this prob. mines happened twice now in last 2 weeks. tilt= fully open, closed=anywhere it wants  ::) ::)
i did see somewhere you need to clean a disc in there, is this correct???
richie
Post by: Entwood on 15 May 2008, 11:32:04
When I first got an Omega ... some years back .. I was told to open/close/tilt/close the sunroof at least once a month (and to run the aircon for 10 minutes a month) as it keeps the mechansim "clean and free"... I've done this and - touch wood - I've had no problems..
Now it is probably either an "urban myth" , an "old wives tale" or probably just "bo***cks" .. but it costs nowt and takes but a moment ...
Post by: Richie London on 15 May 2008, 11:42:19
i use mine quite a bit as i (http://emoticons4u.com/smoking/rauch10.gif) will try that though.
richie
Post by: cbs2 on 15 May 2008, 22:30:49
Had the same problem, and I think I've fixed it.
remove the interior light & the sunroof switch from the panel.
around the sunroof spindle, there is 2 clips. Push these in with a screwdriver & push the sunroof spindle INTO the panel.
Remove 2 screws in the interior light recess, & pull the sunroof rubber away from the edge of the panel, then unclip the whole panel.
The sunroof motor is now exposed. In the centre of the black box is a torx head screw recessed into the box. remove this then prise open the clips around the edge of the black box.Once removed, The disc at the top is what causes the probs seemingly.take the disc off the spindle & clean with WD40. Mine took 2-3 cleans. Then give it one more spray but don't wipe off, leave it to dry then reassemble.
I did the reset, but you might not need to.
Mine works fine now
Post by: Richie London on 15 May 2008, 22:33:31
nice one cb, will try this myself tomorrow,
richie
Post by: Mr Skrunts on 15 May 2008, 22:38:25
Good advice on the aircon.  I didnt use mine for ages on the Carlton Diplomat.  Went to you the car one day there was something that felt like it had leaked in the car.  When summer came round the guy who tested it said something about corroded pipes.  Told me to run the aircon a minimum of once a month but weekly was better.
I was also told that some volvos automatically circulate the aircon when the car is started up.  Dunno if its true, dunno if the Miggys have anything like this either.
Post by: Ian_D on 16 May 2008, 00:51:41
Turned my switch to 'Closed' the other day... Sunroof closed, then opened back up again to where it was before! ;D
Think its also down to pot luck...
My dad drives a 98 Plate Astra.
He’s had the car 5 years at least. Aircon gets used maybe 3 or 4 times a year (in summer) - never turns it on to circulate gas etc every week / month.
His car NEVER gets serviced, its used on tiny journeys  too:'(
Engine rattles and bangs... Radiator leaks.. List goes on,
BUT the Air Con STILL blows ice cold
God knows how!  :o
Post by: jemis on 16 May 2008, 09:13:12
Mine works fine now
I will give that a go, I won't get a chance untill next week though, got the cossie in bits this week.
Post by: FRE07962128 on 16 May 2008, 13:09:42
Yes you are right Entwood :y;  this is what I was originally instructed to do by the Vx manual with my original 3.0 Elite, and have done it ever since.  Like you I have (touch wood!) never had a a/c - c/c problem. These systems, like all other parts on any machine need regular 'turning over' to keep parts lubricated, free, and in running condition. ;)
Post by: bappy on 16 May 2008, 13:15:07
might just be a grubby switch.
My s/r was mucking around, not opening or closeing at all.. alls I did was hold the switch up hard and spin it back and forth... made a lovely scratchy noise  :-?
I know thats probably a really bad thing to do regularly to what is probably a fairly delicate switch assembly but it must have scraped and corrosion/dirt off coz it works perfectly now.
Like I said it's not the sorta abuse that switches like that are made for but if you dont have time to dismantle & clean it properly at the moment you might want to give that a go, takes 20 seconds and if it cures the problem (or makes it worse lol) then you'll know its a switch problem.
