Omega Help Area => Omega General Help => Topic started by: Nickbat on 19 May 2008, 12:47:11
Title: Smell of petrol
Post by: Nickbat on 19 May 2008, 12:47:11
For some time now, I've noticed a smell of petrol from the rear of the car. This ONLY occurs when the car is first started in the day; thereafter for the rest of the day there is no smell. I've inspected for corrosion under the plate in the boot, but found no signs. I can't see any obvious signs of physical leakeage around the fuel lines by the pump/filter.
Any ideas gratefully received!
Nick
Title: Re: Smell of petrol
Post by: Kevin Wood on 19 May 2008, 13:40:22
I had this last summer. Thought it was a leaking fuel filter but that didn't cure it and there are certainly no leaks anywhere. :-/
I haven't noticed it for months. Be interesting if it comes back now the weather is warming up.
Post by: FRE07962128 on 19 May 2008, 17:23:13
I once had this on a 1996 3.0 Elite, especially after filling up with fuel.
I put it down to the tank breathers, especially in hot weather, and never suffered any adverse situations. :y
Post by: Kevin Wood on 19 May 2008, 17:30:07
The tank shouldn't be open to atmosphere. The only breather is via the charcoal canister which vents into the intake when the engine is running, hence all fumes from the tank are burnt rather than polluting the environment.
Post by: FRE07962128 on 19 May 2008, 17:33:10
Even in pre-facelifts Kevin?
Post by: TheBoy on 19 May 2008, 17:33:55
Yup
Post by: FRE07962128 on 19 May 2008, 17:37:58
Yup
Right, thanks. :y
I just knew that when I changed tanks over on both a Carlton and Senator they had breather pipes that seemed to be open to the elements, but obviously I misunderstood where they went! ;D ;)
Post by: perfferle on 19 May 2008, 20:37:21
I have the same petrol smell with my miggy - any ideas on the petrol smell? is this 'normal'? :-?
Post by: Kevin Wood on 19 May 2008, 21:42:36
Right, thanks. :y
Can't remember when charcoal canisters came in but I believe it was around the time when cats came in (they need a lambda loop to compensate for the change in fuelling when the tank fumes are burnt) so it's possible that some Carltons / Senators didn't have them.
Post by: markey mark on 19 May 2008, 21:53:05
it will be the inspection cover on top of tank the two pipes going to it will have started to crrode and when the weather warms up petrol expandes and weeps !! :y
Post by: HerefordElite on 19 May 2008, 21:55:56
Yup
Right, thanks. :y
i didn't realise Carltons/Senators were pre-facelift Omegas? ::)
Post by: perfferle on 19 May 2008, 22:18:47
WEEPS!
You mean that the petrol is simply evaporating??
Can this be fixed or replace pipes? :(
Post by: markey mark on 19 May 2008, 22:34:44
yes you losing fuel fella ! yes it can be replaced not repaired !! :y
Post by: perfferle on 19 May 2008, 23:43:46
any idea what parts i need to get? :-/
Post by: Nickbat on 20 May 2008, 09:45:44
This is what Markey's talking about:
http://www.omegaowners.com/forum/YaBB.pl?num=1186065848
I did check mine and it seemed OK, but maybe I need to do a more thorough investigation.
Nick
Post by: Kevin Wood on 20 May 2008, 10:00:35
The tank cover on mine is OK. I doused it in Waxoyl while I was there as they do corrode.
Post by: perfferle on 20 May 2008, 21:40:40
Brillant guys! :y
Will be calling Vx tomorrow (and Andrew Page) to get plate and get this sorted DIY :)
