Omega Help Area => Omega General Help => Topic started by: shanjon on 18 May 2008, 02:19:52
Title: strange noise
Post by: shanjon on 18 May 2008, 02:19:52
driving along today i noticed a strange noise sort of like a whirring coming from engine accompanied with a low pitched whistling sound,
i had a look when i got home and found chunks of the sepentine belt missing , any ideas?
im thinking its an ancillary item rather than engine as i have no eml and car is driving properly
Title: Re: strange noise
Post by: perfferle on 18 May 2008, 08:37:26
Sounds like your aux drive belt is failing possibly due to a siezed tensioner pulley - which is common.
On the 2.5 the tensioner pulley is top left pulley facing the engine standing in front of the car.
Be careful driving the car in this condition since the pulley ususlly is locked and plastic bits will melt off possibly tearing the belt if you continue to operate the engine.
There is a previous thread somewhere for detailed checks on this problem :y
Post by: batista on 18 May 2008, 08:43:48
i had a similar prob,it was alternator siezed :y
Post by: perfferle on 18 May 2008, 09:01:53
You need to check the belt path and see if there is a siezed pulley for the alternator, tensioner, A/C
To remove belt see http://www.omegaowners.com/forum/YaBB.pl?num=1209567472
Post by: geoff on 18 May 2008, 10:21:41
tensioner is best bet did this on brother in laws 2.5 not to bad a job to do :y :y :y
Post by: shanjon on 18 May 2008, 15:21:32
than guys i will have a look , maybe try running engine for a few secs without belt just to make sure noise goes and its not somewhere else
Post by: shanjon on 18 May 2008, 15:23:46
hopefully it is an ancillary , as i have got a spare engine i can rob bits off of temporarily
Post by: shanjon on 18 May 2008, 20:32:50
all of you guys that said tensioner you all get a star :y,
the tensioner pulley bearings had gone,
Post by: geoff on 21 May 2008, 06:31:12
super not too bad a job 8-) 8-) 8-)
Post by: shanjon on 21 May 2008, 11:56:38
twas the worst belt ive ever changed , well the belt and pulley were easy but it was the amount of stuff i had to take off just to get the belt on and off
