Omega Help Area => Omega General Help => Topic started by: Beconboy on 21 May 2008, 18:25:33
Title: sampler fan
Post by: Beconboy on 21 May 2008, 18:25:33
how easy is it to change sampling fan?
Title: Re: sampler fan
Post by: Marks DTM Calib on 21 May 2008, 18:54:56
Easy enough to change but, it wont be the fan, it will be the driver electronics on the main climate PCB.
Post by: Beconboy on 21 May 2008, 19:34:19
u]
how easy is that to change?
Post by: TheBoy on 21 May 2008, 19:41:16
May be easier to replace panel if you're not good with electronics.  Seem to recall a fair amount of surface mount around that area...
Post by: Beconboy on 21 May 2008, 19:44:58
oh well thats me knackered then ;D new panel me thinks
thanks for the answers :y
Post by: Marks DTM Calib on 21 May 2008, 20:40:58
I dont bother repairing as quite clearly there is a design deficiency in the circuit.
I fit a 12V 25mm x 10mm PC fan in its place (requires a little bit of modding)
Post by: Beconboy on 21 May 2008, 20:45:01
is that the 25 25 10 mm 1 you can buy from maplins for a fiver?
Post by: Marks DTM Calib on 21 May 2008, 20:58:24
Thats the bugger!
Remove the old fan adn screw the new fan across the circular opening in the rear plastic cliamte panel moulding where the old fan used to draw air from.
Then connect the two supply wires (blac/red, ignore the third tach wire) to the outer two PCB holes left by the old fan.
Power it up quickly to make sure the fan is sucking and not blowing.
re-assemble and its job done!
Post by: Beconboy on 21 May 2008, 21:01:11
thanks for the quick reply will have a go at weekend if i balls up
me thinks new panel ;D :y
