Omega Help Area => Omega General Help => Topic started by: easty64 on 01 June 2008, 21:50:00
Title: help needed
Post by: easty64 on 01 June 2008, 21:50:00
hi guys
i bought ma 2.2cd last week i have had a auto box problem. We got the car serviced all belts done and gearbox oil and filter changed the car keeps putting it self into winter mood when put into drive. we tech 2 the car and it comes up with auto trans module faulty or the cables to the module. Does any member know where the module is in the car thanks
ian :y
Title: Re: help needed
Post by: TheBoy on 01 June 2008, 21:54:19
The ecu? mounted up above alarm ecu, which is behind drivers kick panel.
Post by: easty64 on 01 June 2008, 22:05:53
thanks theboy
is that the ecu for the auto box mate
Post by: TheBoy on 01 June 2008, 22:29:28
thanks theboy
Yes. About 6" x 4", says Bosch Transmission Control Module on it.
Post by: Taxi_Driver on 01 June 2008, 22:33:59
What are the signs that its in winter mode???
Pulling away in 3rd??? No kickdown??? EML on????
Its a 2.2 ....... could be camshalft sensor........sounds likely for a 2.2  :-/
Is P0340 mentioned on the list of codes??
Post by: TheBoy on 01 June 2008, 22:35:34
Where are you located?
Post by: easty64 on 01 June 2008, 22:40:47
hi guys
cant remember the codes will get them tommorow the cars pulls away in a higher gear till it gets to about 30mph then its fine, if you start the car then put into sports mode then select drive the take sport mode off its fine.
theboy i am in ayr
Post by: Taxi_Driver on 01 June 2008, 22:46:17
hi guys
theboy i am in ayr
If P0340 is on the list......its the camshaft sensor  :y
If P1700 or P0700 is mentioned (g/b codes) get the g/b ecu read......if the g/b ecu complains of can bus errors........ignore them........2.2's seem to suffer those error codes  :y
Post by: TheBoy on 01 June 2008, 22:52:02
I should add I have never heard of a faulty gearbox ecu.
Post by: easty64 on 01 June 2008, 22:53:23
cheers mate will check them tommorow
Post by: VXL V6 on 01 June 2008, 22:57:21
hi guys
theboy i am in ayr
It will do when you start the car from cold. It's the cold start program. Shouldn't do it when the engine is warm though.
Post by: TheBoy on 01 June 2008, 23:01:22
hi guys
theboy i am in ayr
No - cold start program is when it holds lower gears...
Post by: easty64 on 03 June 2008, 23:04:38
hi guys
sorry for not gettin back work stuff,
i have located the module it says its a delphie model, i have also found that the camshaft sensor is faulty, i have been told that it could be the trouble
Post by: rickyboy on 04 June 2008, 10:02:32
Camshaft sensor can cause all sorts of problems.  If you replace this I would imagine the car will be back to normal.  Make sure you buy genuine vauxhall as cheap ones of ebay and the like tend to be a false economy.
Post by: Markjay on 04 June 2008, 13:53:26
...or engine ECU, me thinks?
