Omega Help Area => Omega General Help => Topic started by: dbug on 04 June 2008, 21:14:52
Anyone know part nş for crank sensor for 1998 2.5 V6 Elite? It is the "square" plug, rounded corners.
Thanx
This is the part number of the Crank Sensor I bought for our 2.5 1998 Elite :y
Crank Sensor = 90492061
Thanx - whats the difference between that one and part nş 90492006? Did yours have "square" elec plug?
Mine was the Part Number I have posted, they (local VX) called "Oval" as it has radiused corners.
The other one apparently is known as "Square" as it has square corners..
Hope that helps mate :y
Think mines "square" altho obviosly slight rad on corners. When does rad become large enough for plug to be called oval??
Does your Crank Sensor look like this?
(http://i155.photobucket.com/albums/s304/Loo-knee/enginepics013.jpg)
From memory think mine has squarer corners. Wont have time to pull out scuttle until weekend to look.
Thanx for pic - at least i know what the "oval" plug looks like.
I have option on a new gm "square" one very, very cheap before weekend - if its wrong guess i can always flog it here!! :y :y
The "Oval" one was just less than £50, the "Square" one was around £70 if I remember rightly :y
Only wanted one as a spare (heard about tb's problem in france!) - guess i'll probably get this one and check both elites for suitability. If no good for either i'll sell on - should sell ok as its genuine gm and brand new!
Will post up outcome.
