Omega Help Area => Omega General Help => Topic started by: daveball on 04 June 2008, 12:32:31
Where can I find the model or type info for my Philips Carin system fitted in to the boot roof of my 3.0 Elite 1999 pre facelift. Is it possible to updae the software if needs be, the system works almost fine on its present 1998 Navtech disc.
Dave
Dave
Welcome Dave,
Sory not an expert ont his issue, none of my two Omegas were Elites so no SatNav... but my understanding is that you can get an updated CD for the Carin system off eBay. Hopefully someone more experienced should be able to give more info shortly...
Go settings > System Info
What H/w is it - 581? What S/w is it?
I don't know what the unit is, I have tken the cover off but I can't see any model nos that are meaningful. I see discs for sale on EBAY but they are defined by Carin model Nos and not by the car.
Dave
Cheers Boy I'm being thick I see what the first bit of your message means. Will go and have a play now.
Thanks
Dave
I don't know about updating software on the sat nav but you can get the up to date dics for them
A new disc (genuine) will have any software updates on it, and these will be detected/installed the first time you run the new disc.
Odds on it's a 582 and Tele-atlas is the disc to go for.
As long as Carin is listed it will work. I have a 2005 disc in mine that came out of a Laguna :)
Get the following info
Ident No SY582/7
HW ID 0203
SW ID 0230
Prod date 99/09
dave
As above, it's a 582 !
Ident No SY582/7
HW ID 0203
SW ID 0230
Prod date 99/09
dave
582 on latest s/w
I have a 581, and run a july 07 map in mine.
My Sat Nav must be faulty then coz it just s seems like its going to load but then doesnt & spits out the cd, in end bought a Tom Tom..
Is there a way of turning the destination guidance off, but still getting the sat nav to show the current road location and maybe point to the next main road.
not that i am aware but you might be able to turn down the sound to zero maybe?
Done that, and found the stand by setting.
Have had a good look through the settings and found all the system detail, also found part of the display shows the current volts, was showing 12.4 volts and my car battery was stuffed, so going to check it again now I have the new Vx GO battery fitted.
