Omega Help Area => Omega General Help => Topic started by: mike213735 on 08 June 2008, 09:12:47
Title: Eratic Idle
Post by: mike213735 on 08 June 2008, 09:12:47
Hi,
I have a 1998 2.5 Omega and I think there is a problem with the idle speed.
First of all, it hovers around the 500rpm mark, which stikes me as a bit on the low side.
The other thing is, the idle is eratic. It's as if you turn on the air con, the revs drop and then are corrected?
I have no warning lights on the dash...
I have cleaned out the ICV thinking that would cure it but it made no difference.
What should I try next?
Thanks
Mike
Title: Re: Eratic Idle
Post by: perfferle on 08 June 2008, 09:57:00
I had that same problem and cured it last week by blocking off my EGR valve.
Other issues could be ignition spark related, i.e plug leads defective / Dis pack defective.
Post by: Danny on 08 June 2008, 09:57:29
i cleaned throttle body icv and breathers all at the same time
to idle at around 500RPM is normal
i had small engined cars before my omegas and also thought this was low, my elite idle's at around 450-500 and my 2.0 GLS was a touch higher at about 550-600. its normal
Post by: TheBoy on 08 June 2008, 14:10:42
idle ok, but clean icv, as it sounds slow to respond.  If idle is lumpy, look for air leaks
