Omega Help Area => Omega General Help => Topic started by: The Duck. on 11 June 2008, 17:32:37
How do u set the idle on a 96 2.5 TD CD.
It is fully controlled by ECU, why do you need to adjust. If it is not around 700rpm, then you have another problem.
There is a small adjustment available via Tech2
it's hovering around 500rpm and is causing the car to vibrate at such low rev. How do i adjust via tech2?
right, in that case you need to work out why its that low, as ecu will try to keep around 700rpm. I don't think (could be wrong) that ecu will allow you to adjust that low.
Tech2 - from memory its under either Additional Functions or Programming
Cheers thanks for the info
If you have access to a (real) tech2, look for engine DTCs, and also live data, checking what desired rpm is, compared to actual.
Is that the same for th 2L 16v x20xev ecu controls it? Only have noticed some sort of adjuster at the carb end of the throttle cable :question
You aint got a carb ;)
2.0l petrol, idle controlled by Idle Control Valve, itself controlled by ECU. Do not adjust the screw on the butterflies, you will bugger up the idle.
Couldn't think what else to call it.
Nice one TB i may have been tempted :y
