Omega Help Area => Omega General Help => Topic started by: dom1 on 10 June 2008, 21:47:30
Title: oil on one valve V6 estate
Post by: dom1 on 10 June 2008, 21:47:30
I'm following the cam cover gasket change guide, got to the point of taking off the fuel rail and thought I would have a peer down at the valves, one valve (in closed position) has a little puddle of oil whilst all the others that are closed are dry is this normal or is it time to worry ?   :o She has been standing for 2 years and apart from oil in the spark plug wells she was running fine before I took her off the road, also there is no burnt oil residue on the valve. Any body have any thoughts ?  :-?
Title: Re: oil on one valve V6 estate
Post by: Auto Addict on 13 June 2008, 07:05:21
It will probably burn off, when you start the car.
Post by: mkaminski100 on 13 June 2008, 09:43:19
Is it just clean oil or burned? Might be stem seal but there would be clean oil.
