Omega Help Area => Omega General Help => Topic started by: 2dogs on 18 June 2008, 12:31:17
Title: oil change
Post by: 2dogs on 18 June 2008, 12:31:17
Hi Guys,
Ive read on here that you can change the oil on a 2.2 auto box, has anyone got any top tips for me.
Thanks to everyone who leave feed back, it's really appreciated.
Regards.....dogs
Title: Re: oil change
Post by: Jimbob on 18 June 2008, 12:43:58
yes, get someone else to do it ;)
Not a bad job, but a bit messy.
Basically...
Get replacement gaskets / Filter (JPAT are a good source, or Dave Kember in the back of the Autobahn mag if you have one)
although you can use liquid gasket, and wash the filter in parafin as it doesnt get blocked)
Drop both sumps off the gearbox, i would leave a couple of bolts loosely in so you can 'slosh' the old atf out.
drop and clean both sumps, remove magnet and clean, remove old gasket.
replace or clean filter
refit sumps
fill with nice new dex3 (may I suggest Fuchs titan 4000 from opie oils)
through the level plug, you can use a large syringe for this, or a garden pressure sprayer also works well.
fill till fulid dribbles out, get the car level, start it and work through the gears, top up again, level car, fit plug back in.
Go for a few miles drive, and recheck the level (again jack it up, fill to overflowing, lower to flat, all with engine running, raise to refit plug.
You are now done and have changed about 2/3 of the atf.
Some people do this again after a few weeks to further dilute the atf you cant change.
Post by: ians on 18 June 2008, 18:01:00
..as the man said.
One thing to note is that if you undo the level plug with the engine off , about 1-2 L of oil will come out.  Fair enough if you are changing it, but best be ready to catch it - unless you're parked on someone elses drive  ;)
