Omega Help Area => Omega General Help => Topic started by: shanjon on 24 June 2008, 22:49:03
Title: alternator going i think
Post by: shanjon on 24 June 2008, 22:49:03
i put a new crankshaft sensor on today, but tonight i have noticed the battery light glowing slightly (very barely), but if i turn lights off or air con off it goes out,
i reckon its the alternator but does anyone think by any remote chance its linked to the crankshaft sensor
Title: Re: alternator going i think
Post by: Entwood on 24 June 2008, 22:51:53
I doubt the two are linked ...
Check that neither battery terminal is getting warm, corrosion/bad connections can cause this problem. If you have a multimeter check for battery voltage with engine stopped about 12.6v, with engine running about 14.4 v
Post up your results   :y :y
HTH
Post by: shanjon on 24 June 2008, 23:03:14
+ terminal is really hot ,,,, and voltage is 12.04 not running and 13.11 running
Post by: Entwood on 24 June 2008, 23:17:14
Disconnect the + terminal and give it and the battery terminal a damned good clean, check that the crimped lead is firmly in the socket. I think that you have found the problem .. there should be NO rise in temperature at all ... you have a bad connection.
 :y :y
Post by: shanjon on 24 June 2008, 23:26:06
 :y thanks m8 :y i will have a look in the morning and post up my findings :)
Post by: JamesV6CDX on 25 June 2008, 01:38:32
I agree 100% with Entwood..
It will be either a high resistance in the + cable, OR an old/weak battery that's not holding a good charge :y
Post by: Kevin Wood on 25 June 2008, 09:50:18
Normally the connection where the big wire from the starter / alternator is crimped into the battery terminal works loose. Best option, if the wire is not mullered, is to get a new battery terminal with screw clamps for the wire and replace it.
