Omega Help Area => Omega General Help => Topic started by: Arrolman on 20 June 2008, 18:23:26
Title: Glow plugs on way out?
Post by: Arrolman on 20 June 2008, 18:23:26
Hi,
After the glow plug light has went out it struggles to turn over for a few seconds. If I wait any longer than 2 seconds after the light is out it will take about 5-10 seconds to kick into life. Starters spinning fine, plenty of fuel and a good battery. Glow plugs then?
Title: Re: Glow plugs on way out?
Post by: psychnurse on 20 June 2008, 18:26:24
Sounds like my old citroen. That had the same and had glow changed... was sorted... so maybe. Im sure someone more qualified than myself will let you know  :y
Post by: HGV mechanic on 20 June 2008, 18:29:34
possibly, , try turning the the key on and off a few times then start and see if it fires up quicker, or u could take the plugs out and useing jump leads off a battery and test them to see, if the glow ok
Post by: Dazzler on 20 June 2008, 18:29:45
What do you mean by struggles to turn over?????
Do you mean like the battery is nearly flat or do you mean it turns over fine but will not quite catch straight away??? :-/
Post by: Lazydocker on 20 June 2008, 18:36:10
Could be... Could also be the fuel bleed off pipes.
Post by: MickAP on 20 June 2008, 19:41:17
Does it start OK when the engine is warm, first turn of the key?
If so then it could be the glow-plugs.
Do you know how long they have been in the car? if you are approaching say 100,000 miles or have passed that then maybe it's time they were changed.
Mine gave up at around 90,000 and I believe they may have been the originals.
Mick
Post by: Omegatoy on 20 June 2008, 21:20:42
mine have now done 113281 miles still original plugs but i have for the last 8month had to turn ignition on wait till glow plug light goes out, the turn off ignition and back on again wait till light goes out and it starts immediately, if i try to start with just one go it wont!!!well it will after about 7seconds of churning on starter but its easier to do glow plugs twice!!!
Got new glow plugs to go in just havent got round to it yet!!!  :'(
Post by: Andy B on 20 June 2008, 21:26:22
To much lazing in the sun! C'mon Graham! Pull your finger out!  ;D  ;D  :y  :y
Post by: Omegatoy on 20 June 2008, 22:10:20
hardly!!! when working on cars out here you have to be very careful when picking up spanners! 106 degree heat in bright sunlight makes you drop them again very quickly!!!!! and i dont get paid to fix me own car!!!! ;D
Post by: psychnurse on 20 June 2008, 22:13:54
My sympathy is almost genuine......  :y :y :y :y
Post by: Lazydocker on 20 June 2008, 22:25:54
Sounds like it is plugs then  :y :y :y :y
Post by: TheBoy on 20 June 2008, 23:22:45
Measure resistance of each glow plug, should be around 1ohm. In the main relay box is the glowplug relay. Unplug, and measure from here, as its easier than getting to plug itself.
Post by: Arrolman on 21 June 2008, 14:16:47
Car will turn over fine once running, took it to local pub this morning, left it for 45 mins, switched on to glow plug setting, no light (presume engine still warm enough) but spun the starter for a few seconds before kicking into life. So either glow plugs or battery, goin to swap battery out of my landrover and see what happens. Will I lose my radio etc if I pull the battery out? Don't know where my code is for it  :-/
Cheers,
Iain
Post by: TheBoy on 21 June 2008, 18:40:51
Cheers,
Iain
Its likely you'll lose radio.
Have you measure glowplugs with meter yet?
Post by: MickAP on 21 June 2008, 18:41:44
Cheers,
Iain
Sure sign if it starts when warm but not when stone cold it's glow-plug failure.
I had mine fail on me in winter, and so long as I kept the engine warm it started no problems. Greenflagg started it up no problem from cold, just a squirt of Easi-start into the air intake pipe got it going. Only use this method to get you out of trouble though as not recommended to use too often.
Mick
Post by: Arrolman on 21 June 2008, 18:44:16
Hi,
Not had a chance to get out at it, rain is thundering down. Going to get new pluigs for it on monday. Also noticed that the fuel cap lock tab's broke, so more things to fix :o
Cheers,
Iain
Post by: TheBoy on 21 June 2008, 18:54:32
Hi,
Cheers,
Iain
Measure they are faulty before changing willy-nilly ;)
Post by: Arrolman on 21 June 2008, 18:57:02
£30 or so is worth it to get them changed, car is on 74,000 miles and there was no service history, everything i've changed so far has been original, even the oil!
Cheers,
Iain
Post by: TheBoy on 21 June 2008, 18:59:35
Cheers,
Iain
It adds a further complication to the diagnoses randomly changing parts.  Seeing as it takes about 2 mins to check all 6 are OK (bit longer pinpointing which one is faulty if one is), its worth doing first.
Post by: V8S on 25 June 2008, 11:52:32
How difficult is it changing glow plugs on the 2.2 DTi?
I'm having starting problems too. I do not think it is likely to be the glow plugs but I'd probably want to replace them anyway as my car has just reached 100k.
