Omega Help Area => Omega General Help => Topic started by: Chris-Collins on 28 June 2008, 10:20:03
Title: 2.5 TD Flexi Plate (Flywheel)
Post by: Chris-Collins on 28 June 2008, 10:20:03
Hi to all
Does anyone out there know if the drive flexi plate (Flywheel) can be fitted incorrectly.
Ill tell you why I have this 2.5Td and I am trying to check the timing (Because of bad satarting) I have checked every thing else, now Autodata says to Turn engine to Cyl No.1 at TDC and insert locking pin to Flexi plate, the locking hole is not at No.1 TDC it is elswhere it is at another position
Please Can anyone advise me on this subject
Regards and thanks in advance
Chris Collins
Title: Re: 2.5 TD Flexi Plate (Flywheel)
Post by: Omegatoy on 29 June 2008, 21:32:52
sounds like the box has been off at sometime then,
how fsr is it out do you know?
Post by: Chris-Collins on 30 June 2008, 07:46:33
Hi Omegatoy
I would say about a third it is difficult to say, 2 and bit ofinduction pin
distance!!
Can the Flexi disc be fitted incorrectly??
Regards Chris
Post by: Omegatoy on 30 June 2008, 08:54:29
that sounds right then the flex plate is only held on by three bolts so equal spacing, they are accessed thru the bung at the bottom of the bellhousing or thru starter motor hole may be worth you undoing them and lining it up properly so you can check your timing but i bet it aint far out if at all,take it you have checked glow plugs and filters etc?
Post by: Marks DTM Calib on 30 June 2008, 09:02:26
I remember that when we did TB's timing, there appears to be other places that the locking pin will go in which are a mile out.
The correct position was a swine to find and fit.....took a lot of buggering about!
