Omega Help Area => Omega General Help => Topic started by: psychnurse on 08 July 2008, 18:09:03
Title: Alloy lock key
Post by: psychnurse on 08 July 2008, 18:09:03
The cover that well... covers the alloy has a special key to prevent theft ect. Where can i get a replacement as mine is not present and the allys have to go!  ;)
Title: Re: Alloy lock key
Post by: MadMark73 on 08 July 2008, 19:41:29
The best way to get the covering plate off is to use a small drift in one of the holes in the locking screw and a hammer. A new key and locking screws is available via ebay for about £10. Hope this helps.
Post by: Andy B on 08 July 2008, 19:46:14
The 3 prong key for my Senator's wheel nut cover had a 3 letter code, I think you need this code really if you want another to fit. An alternative is a pin punch & 2lb knocking stick or a pair of snipe nose pliers in 2 of the holes & then use a screw driver between the legs to lever the 'bolt' head round.
Post by: psychnurse on 08 July 2008, 19:53:13
Is a pin punch just a small elongated metal peice? similar to a scriber or the like??
Post by: Andy B on 08 July 2008, 19:56:07
I suppose so!
(http://tbn0.google.com/images?q=tbn:R2Ldzkfv8UgtCM:)
Or a centre punch would do the job
(http://tbn0.google.com/images?q=tbn:H_v02QJJzmAmCM:)
Or .... if nothing else ..... I reckon a decent sized nail would do!  ;D
Post by: psychnurse on 08 July 2008, 19:58:01
 :y :y :y :y :y
Thanks matey. I was no good at woodwork at school either  ::)
Post by: philhoward on 08 July 2008, 20:55:39
I was going to suggest the pair of long/snipe nose pliers...
Post by: psychnurse on 08 July 2008, 20:58:44
Yeah that may work... Im sure they will all be loose anyway, mot other thing seem to be. One is actually hanging off anyway.
Post by: JezInBrum on 08 July 2008, 22:11:34
Vaux do sell a new key & bolts as a set, maybe best to replace them once you have got them out. Not sure on cost though.
Also long nose pliers in the holes & using a screwdriver as a bar should do the same job for removal. Have seen it done before.
Oops missed pevious mention of that idea  :-X
Post by: psychnurse on 08 July 2008, 22:14:06
Useful to know about new vx sets though. I may well conider that. are they TC part do you know?
Post by: Entwood on 08 July 2008, 22:19:51
If long nosed pliers and a screwdriver pry-bar remove the locknuts so easily .. is it worth fitting them at all ??
I'm struggling to see how the pliers/screwdriver thing will undo something torqued up to 110 Nm .. or am I missing something ???
Post by: psychnurse on 08 July 2008, 22:25:43
A very good point enwood! Are they not ment to be anti-theft? Mind you somebody with a screwdriver at a wheel would be supicius... but would anybody notice or care in reality?  :-/
Post by: philhoward on 08 July 2008, 22:29:40
Have to confess, i'm thinking about the bolt holding the centre cap on mine - M8 from memory.  Universal locking bolt removing sockets available at your local tyre fitter or off ebay...so as you say - whats the point??
Post by: JueV6 on 08 July 2008, 22:31:09
psyconurse is talking about the security screws that hold the centre caps on if i'm reading right :y
Post by: psychnurse on 08 July 2008, 22:33:07
Thats right  :y
Post by: Entwood on 08 July 2008, 22:42:50
Sorry , thought he was talking about security wheel nuts  !!! My bad
Post by: psychnurse on 08 July 2008, 22:43:44
??? Do you mean the main wheel nuts??
Post by: Andy B on 08 July 2008, 23:24:02
We'll forgive you Nigel! .... Just this once.  :y  :y  :y
Post by: Entwood on 08 July 2008, 23:30:55
I'm pleased about that ... no ... really .. I am .. :)
Post by: markey mark on 09 July 2008, 00:00:50
well your new set has a key with it matey  :y
Post by: psychnurse on 09 July 2008, 10:06:50
Thats cracking news!! Just got to brutalise the old ones to remove then I guess.  ;D
