Omega Help Area => Omega General Help => Topic started by: webby23 on 12 July 2008, 19:19:51
Title: Erratic and high idle  (amended!!)
Post by: webby23 on 12 July 2008, 19:19:51
HI
I know this may have been discussed before but can anyone help me please....
I have a 2001 2.0 auto CD and its a great car, never let me down, even been poland in it without missing a beat......
However there is a problem in that sometimes the engine idles high, around 1200-1600 rpm.
Other times it idles at 750rpm perfectly happy. I would say it over revs probably 20-30 per cent of the time. regardless of engine temp, trip distance etc etc
Can anyone help with a bit of advice please?
We are in Nottingham
Thanks
Webby
Title: Re: Erratic and high idle  (amended!!)
Post by: Auto Addict on 12 July 2008, 21:42:25
Could be the throttle body butterfly sticking, when was the last time it was cleaned, along with the breathers?
Post by: webby23 on 12 July 2008, 22:22:39
Thanks for your reply
I think the breathers were cleaned out along with the idle control valve at a service about 6 mths ago.
Is the butterfly clean out a job i can do myself?
Thanks
webby
Post by: davlad22 on 12 July 2008, 23:14:50
This should give you a bit of bedtime reading mate!....
http://www.omegaowners.com/forum/YaBB.pl?num=1207387811
Post by: ians on 13 July 2008, 11:08:58
Well worth following the guide in its entirity and using new gaskets (pennies from Vx) on the throttle body and idle control valve.  Also check that none of the vacuum pipes have come off.
Post by: webby23 on 13 July 2008, 14:47:47
Brilliant guys
Thanks for your input.
Post by: JezInBrum on 13 July 2008, 17:07:24
A vectra i owned revved highly. pipe from the fuel purge valve to throttle body had come off
