Omega Help Area => Omega General Help => Topic started by: doz on 16 July 2008, 16:25:23
Title: Heater bypass valve
Post by: doz on 16 July 2008, 16:25:23
My. heater bypass valve has had the vaccum nipple (ooh err) snapped off. I've plugged the vaccum take off from the the servo pipe but what sort of issues am I going to incounter running the car like this?
Title: Re: Heater bypass valve
Post by: Markie on 16 July 2008, 17:35:45
For the cost of the HBV and the fact its DIY able i would just change it  :y.
If it fails it will make a mess, and an uncomforrtable journey home if it dumps its coolant when your driving.
Post by: doz on 16 July 2008, 17:50:47
I do intend to replace it but I've got to use the car for work till the weekend. So just asking what the consequences are to using it as is
Post by: Markie on 16 July 2008, 17:53:04
in that case be gentle, dont push it and check your coolant / temperature.
Post by: ians on 16 July 2008, 17:53:49
I suspect you will either get lots of heat or none at all. :)
Post by: VXL V6 on 16 July 2008, 18:57:17
I think (but I could very easily be wrong!) that without the vacuum connection you will not get any heat in the cabin - ie. no coolant flow through the matrix.
Post by: doz on 17 July 2008, 22:00:58
seem to have plenty of heat but the aircon is a bit well poo. The compressor is working right. Does this sound right?
Post by: TheBoy on 17 July 2008, 22:05:15
I seem to recall without vac, heat will flow through matrix
Post by: tmx on 17 July 2008, 22:28:58
yes the boy is rite does can confirm as just done myn
