		Omega Help Area => Omega General Help => Topic started by: Arpy on 21 July 2008, 22:16:01
				going to france next month so will need a bulb kit any suggestions
				VX do one...
				Don't VX do one?  Failing that, virtually all motor stores do them, usually contain ones you don't need, but generally go by the headlight bulb (i..e H1/H4/H7).
 Given you normally don't get EVERYTHING you need, get the list of the external bulbs (from the handbook) and go to your local motor factors - might work out cheaper.  Doesn't have to be in a flashy case - any old box will do!
 Usually, you'll need a headlamp bulb, and one of each of the external ones - given there are usually only 2 or (max) 3 types:
 21W single (indicator, fog or brake light)
 21/5W double (stop/tail, or tail/fog)
 5W single - tail light
 and normally a silly 5W capless for the front sidelight, usually the same for the side repeater.
 Don't have a Drivers manual for mine, so don't quote me on the above - this is just from experience!
