Omega Help Area => Omega General Help => Topic started by: sev on 22 July 2008, 14:23:19
Title: Cam Cover gasket and HT Leads Quotes:
Post by: sev on 22 July 2008, 14:23:19
from my local vauxhall...
85.78 per side!!!   what the F!!@
H.T. Leads:
260 for a car kit !!!!
You can buy a set of Magnecor KV85 racing leads for half that!
Any suggestions on alternative cover gasket kits and HT leads?
Title: Re: Cam Cover gasket and HT Leads Quotes:
Post by: Marks DTM Calib on 22 July 2008, 14:30:10
H.T. Leads:
We have a set of genuine cam cover gaskets for sale in the shop......much cheaper.
For leads, bosch ones are quite good enough so try your factors, about 30-40 quid for a set of 6.
Post by: serek on 22 July 2008, 15:31:37
I just buy set of cam cover gasket on vx in st ives  pay 68.15
I use before budget ones they crap every 2 months need chenged
Post by: Marks DTM Calib on 22 July 2008, 15:35:30
64 quid plus postage in the shop and it includes the gaskets for both banks, athe bolt O rings, the correct black sealent and the orings and breather seal so you can clean the breathers out at the same time.
Post by: Lazydocker on 22 July 2008, 15:39:39
If you're after performance leads I might be able to arrange a bit of a discount on  the Formula Power 10mm ones in the link i posted in the thread asking if anyone has used them. The guy has said he'll waive postage for us if we all order within a reasonable time period! :y :y
Post by: markey mark on 22 July 2008, 15:44:39
what sort of time scale we talking fella  8-)
Post by: Lazydocker on 22 July 2008, 15:52:59
Think he's talking about a couple of weeks or so but need to try and sort it later... As soon as I know I'll post the details! Could be said I'm doing it for a selfish reason because I'm definitely getting them and want a discount too! ::) ::) ::) ;D ;D
Post by: Lazydocker on 22 July 2008, 19:20:59
This was my misinterpretation of an email I was trying to read on my phone...  :-[ :-[
See this thread for details! http://www.omegaowners.com/forum/YaBB.pl?num=1216673083
Post by: Marks DTM Calib on 22 July 2008, 21:30:25
By the way, dont expect any improvement what so ever from ignition leads......unless your old ones are knackered.
Post by: Lazydocker on 22 July 2008, 21:49:26
Well aware of that one thanks... I'm more interested in the improved conductance (proven on my Rangie) as I'm just about to fit the LPG kit to mine. Although they did improve the general running of the car, the MPG improvement was marginal. Mind you... It only ever did low-mid teens on petrol to start with, then fit an outdated, single point, open-lop LPG system and you can't really expect much improvement!!!  ::) ::) ::) :y :y :y :y
Also like the fact that he guarantees them for 10 years!! :y :y :y
Post by: v6coop on 23 July 2008, 09:23:50
SEV
That price for the cam cover gasket sounds like it's for the cover and the gasket + o rings. I believe there was a modification to the cam cover on the later models so Vx parts system brings the whole thing up as a replacement. If you tell them you only want the gasket and 'o' rings it will be much less. However as Mark says good deal if you buy them here at OOF. Plug leads are made by BERU I believe if you can find a stockist who will order them for you it might be much cheaper.
Post by: Marks DTM Calib on 23 July 2008, 10:01:14
It will make jack all difference to the spark....
On the old Range rover and land rover engines you had a pissy little distributor, a single coil plus rotor arm and distributor. THe result is a peek spark voltage of about 32-33Kv which drops off as the revs increase......the Omega has a DIS setup (or coil per plug on the later ones) and deliver in excess of 40KV even at higher revs!
They will make only one difference, a hole in your pocket  :y
They are also likely to not have a higher level of conductance (which is the inverse of resistivity) as the leads are designed to be resistive to reduce interference.  :y
Post by: TheBoy on 23 July 2008, 18:44:11
and all genuine GM parts :y
Post by: Lazydocker on 23 July 2008, 19:01:33
Actually that all makes perfec sense... I hadn't looked at it that way!!  :-[ :-[ :-[
I think I'll save my money and stick to the ones that are on there. I don't have any issues at the moment (famous last words!!)
Post by: sev on 23 July 2008, 19:09:12
I'll definitely be buying from the OOF!
I just thought I might as well replace the HT leads whilst I'm at it if i'm going to do the plugs, and belts as well.
I was quoted just under 30 quid for a complete new bosch set from my local motorfactor so i'll be looking there possibly.
I'll definitely look at BERU leads, but i'd like to think that the bosch are to OEM spec at least.
Post by: v6coop on 23 July 2008, 19:31:43
£30 for a set of Bosch sounds like a bargain but are you sure that is for the V6 and not the 4 pot? I fitted a set by Electraspark 6 years ago and they have been great ever since. The originals along with several other pipes and wires had been chewed at by something. I've heard of Pine Martens taking a fancy to them but they are not the sort of animal you get in the garden every day. Must have happened when in the original owners hands. I believe GSF stock the Electraspark set for the V6 Omega at £58.
