Omega Help Area => Omega General Help => Topic started by: omegagoodness on 02 August 2008, 01:07:29
Title: "Automatic gearbox" showing on MID!!
Post by: omegagoodness on 02 August 2008, 01:07:29
when i start my MV6 the MID displays "Automatic Gearbox"...
now this is a problem because my car is a MANUAL!!!!!!!!
i swapped the mid from a 2.5 CDX model as there were pixels missing from my original MID.
how do i get rid of this "warning"????
many thanks in advance.
mark and steff.
Title: Re: "Automatic gearbox" showing on MID!!
Post by: paul.c on 02 August 2008, 02:23:04
you will need someone with a tech2.
Post by: feeutfo on 02 August 2008, 07:53:54
couple of members on here have tech 2 but are a fair
Way from you. Always worth a t2 session tho if you
can find one local for a sensable price,give the car a
once over for codes, may be able
To upgrade your software dep on your car.
 Up to you but i would not bother vx with it, too
expensive and quite often they cant use the thing.
Or am i being unfare?
Ps. Thought the screens had to be de paired before
Removal? Or is that just the colour ones. Anyone?
Post by: MutantCav on 02 August 2008, 08:48:25
Just the later ones Chris...yeah the MID was obviously out of an auto car...needs tech 2 to tell it that its now in a manual one...
Post by: philhoward on 02 August 2008, 10:28:25
TheBoy can reprogram them..without them being in the car  :y
Post by: TheBoy on 02 August 2008, 12:34:26
if its and earlier mid (yellow and black connectors), and came from same sized engine and car, them cutting a wire will fix. If not same model and engine size, needs reprogramming.
If later mid (grey connector), so many variations, it will need reprogramming.
