Omega Help Area => Omega General Help => Topic started by: loon[mv6] on 02 August 2008, 12:56:42
hello everyone an di hope someone can help me.
i done a search and couldn't find anything so i thought id make a post.
The problem is the power steering has got heavy on my mv6,i have checked the fluid level and it is fine,so i presume there is no leaks,tyres and pressure's are ok and the pump seems to be working ok,well i can hear the pump on full lock.
so has anyone any ideas on this,before i chuck it into the garage and bankrupt myself ;D
i had decided to blame the wife for keep adjusting the steering,but i couldnt see anything that would make the steering so heavy :o
cheers in advance
check the fuse first.number 14 usually. :y
yep your right,ive just checked fuse 14 and its blown,so i have changed it and tried it and it all works now ;D
have you any ideas on why it popped :question
cheers anyways
cheers anyways
Just keep an eye on it -- if it doesn't pop again soon, probably "one of those things" --- fuses age too ;)
cheers anyways
ok,cheers anyways all of you who have replied :y
has the omega got a steering box system and not a rack?
just noticed my mv6's steering feels similar to a friends 124 mercedes which does have a box system?
yes mate, its a box!
Rather than start another topic I thought I'd hi-jack this one! ;D
Has anyone ever fitted a refurb'd power steering pump? I think mines getting a bit tired now. Often when I'm trying to manoeuvre my caravan I also end up fighting with the steering wheel. Compared with its better predecessor ::) the steering has always been a bit heavier, I assume that they were both a very similar sevotronic set up.
