Chat Area => General Discussion Area => Topic started by: Crazydad on 29 October 2007, 19:44:40
Title: Help for a man with two left hands
Post by: Crazydad on 29 October 2007, 19:44:40
who can tell me what this is called??
as i have to fit a new one to my car :-/
(http://i211.photobucket.com/albums/bb52/crazydad_01/Fhrungsgelenk.jpg)
Title: Re: Help for a man with two left hands
Post by: miggy on 29 October 2007, 19:46:17
Ball joint innit
Post by: miggy on 29 October 2007, 19:47:30
Drill out the old studs and replace with nuts/bolts
 :y :y
Post by: JamesV6CDX on 29 October 2007, 19:48:03
I'd be personally doing the whole suspension arm(s)
Post by: miggy on 29 October 2007, 19:49:52
There cheap enough
 :y :y :y
Post by: Taxi_Driver on 29 October 2007, 19:50:50
Thats easy....its called a thingy  :y ;D
Post by: miggy on 29 October 2007, 19:52:19
No its a foo foo joint
 ;D
Post by: Crazydad on 29 October 2007, 19:55:07
your not making it easy for me   :o :(
ok James can you give me more Info??
Post by: miggy on 29 October 2007, 19:58:27
Seriousley mate, i am sure it is a bottom ball joint, you can buy these or you can get the whole suspension arm as mentioned, I am sure jamie will point you in the right direction.
Tap it in on ebay and you will see the whole thing.
 :y :y :y
Post by: JamesV6CDX on 29 October 2007, 19:58:47
If I'm not wrong crazydad, that is the lower suspension arm (wishbone) bottom ball joint
OE ones were rivetted onto the wishbone, so if you were to change just the balljoint on it's own, you would need to drill the old rivets.
Wishbones are only about £25 each, with the balljoint already attached, so I'd be doing the wishbones..
Post by: miggy on 29 October 2007, 20:00:19
 :y :y :y
http://cgi.ebay.co.uk/VAUXHALL-OMEGA-FRONT-2-WISHBONE-ARM-BALL-JOINT-BUSHES_W0QQitemZ280167331847QQihZ018QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
the things on the ends
 :y :y
Post by: Crazydad on 29 October 2007, 20:08:14
i Raise my hat to you both :-[
Thank you very much for the advice, i think that you are both right, in  the fact that it is better to fit new
wishbones.
Thanks James :y
Thanks for the Link pete :y
Post by: miggy on 29 October 2007, 20:13:12
wishbones.
Thanks James :y
No probs mate
Post by: Danny on 29 October 2007, 20:50:02
you're all wrong, its called a " PAW PRINT " ;D
Post by: Crazydad on 29 October 2007, 20:50:42
;D ;D ;D
