Omega Help Area => Omega General Help => Topic started by: sophos9 on 24 August 2008, 22:34:11
Title: Aircon Recharge?
Post by: sophos9 on 24 August 2008, 22:34:11
Can anyone recommend a centre to recharge air con? Been readin about the Kwik Fit Service, has anyone had any good experiences?
Title: Re: Aircon Recharge?
Post by: Black cxd v6 on 24 August 2008, 23:11:02
Had a vectra that loss air-con pressure. When I asked a friend whos an air-con engineer, he said the system needs pressure testing because there must be a leak for the system to lose pressure
Post by: sophos9 on 24 August 2008, 23:20:25
The aircon blows cold but not proper cold, no idea when it was last recharged and I've had the car coming on to 3 years. Kwik Fit do pressure test but as I see it, dont add UV which is a pain...
The air con works fine and components seem to be in good order, kwik fits prices are well competative
Post by: feeutfo on 24 August 2008, 23:46:41
Promise me one thing, what ever you do, do not go to quick fit up. Or Halfarce, i have seen several examples on here of people trying to save a penny at these places and end up spending more than several pounds. Go to an ac specialist, and get the job done properly first time out. You should be able to get a service done for £60 odd and find any leak FIRST, before the gas is blindly topped up only for it to leak out a week later and be back to square one, as has happened with these high st places.
Post by: sophos9 on 25 August 2008, 00:00:28
Yea understand what you are saying. I'm pretty sure there are no problems with the climate leaking as its been 3 yrs of me owning the car and I'm not sure when it was last charged. National Auto Centres do a full service for £80 odd which is inspection, vac and charge - if it leaks after you get a full refund....
Post by: feeutfo on 25 August 2008, 00:34:41
bit confused, air con works fine, but does not get proper cold? If the bottom right pulley with the 4 knobs on is turning with engine running and ac on then the ac is functioning with enough gas to keep the pump turning, if the four knobs not spinning the ac is not working, usually its run out of gas or electrical fault. I had a cdx for 5 years and never touched the gas until one day no ac. It had a leak. If yours has been fine for 3 years and now you have no ac, in my experience you have a leak.
If the ac system and pump are working but your not getting cold air at the vents it may be a vacume problem behind the dash,maybe check the vac pipe on top of the hbv or press and hold off and auto for 10 seconds or so to reset the vents. i have no further experience of that tho. It should be possible to get the temp. down to about 5 or 6c at the vents. Hope helps.
Post by: sophos9 on 25 August 2008, 01:04:47
Works fine as in mechanical function... AC gets colder than outside ambient temperature and easily reaches the 18C however is not as cold as the vectra
No vacuum problems at all, climate control mechanical function is fine, all tested after replacing the heater core a week ago.
With the natural fluon loss that occurs over time in any refrigerant I dont think that min of 3yrs is too bad. Will look for someone that will pressure test and UV just incase
Another job waiting to be ticked off...  :-[
Post by: Banjax on 25 August 2008, 01:57:28
my only advice is to take it to an AC specialist - system needs to be checked for leaks, vacced and regassed - got mine done a month or so ago - £50 :)
take to it to halfords or kwik-fit and they may damage an expensive component - trust me - halfords are good if you need new wipers or furry dice but i wouldnt trust them for anything else
either way its gonna cost you about £50 if theres no leaks(and if there is a leak you need a specialist in any case) - so its a no-brainer
if you're anywhere near perth - i can recommend a good guy  :y :y
Post by: Hog on 25 August 2008, 07:55:31
I've used this company a few times, they are really good.  If there is a leak in your system he can put in a sealant that worked a treat in my old soarer and it's much cheaper than part replacement.
http://www.ac4cars.co.uk/
I would highly recommend them
He's mobile too, does the full vacuum and recharge, dye also if suspected leaks, I wouldn't touch kwikfit personally
Post by: Kevin Wood on 25 August 2008, 11:31:59
LOL I went to Halfords for a new battery a few years ago. (It died at a Motorway services so I drove to the nearest halfords). I decided to take advantage of their "fit it free" service as I didn't have any tools with me and needed it in before it would start.
After telling me that my Laguna was coming up as a "challenging" install (How? 2 terminals and a clamp bolt) they supplied a muppit with a tool box to perform this "challenging" task. Suffice it to say I ended up replacing the battery using his tools. ::)
Halfords certainly don't have the equipment to properly service aircon systems. They will chuck a can of refrigerant in and hope for the best. Kwik fit do have the proper servicing machines but not the first clue how to use them so if anything goes wrong they are stuffed. I'd take it to a specialist.
Post by: FRE07962128 on 25 August 2008, 11:53:31
I would second the above sentiment 110%! :y :y   Do not use Kwik Fittup!! :o :o :o  Go to a specialist. :y
Post by: dbug on 25 August 2008, 16:23:16
Don't go to Kwikcrap - they gassed the estate for £44 - by the time i reached home (10miles) it had lost all gas through a leak - got my money back after an argument and at least pinpointed leak.
Got my local mobile guy out after i had replaced condensor who checked whole system for leaks, gassed it, and rechecked all joints etc using a sniffer.  Cost all in £50
Post by: sophos9 on 25 August 2008, 19:19:45
Thanks for your hep, will stay away from them...
Looked back over the service history, air con was last serviced by Vx at 90k, the car is not on 132k and has not had the aircon touched in 42k!!!
I got a thermometer in the car today and measured the air temp coming from the vents, went lower than 10C (cant tell how much lower as thermometer only went to 10C)
Still, time to get it serviced I think!!
Post by: newhouse on 25 August 2008, 20:07:15
Recommend a company that sorted me out, mobile but has all the latest gear. www.aircondoctor.co.uk. I think it’s a franchise so there may be one in your area. They have a good Q&A section on the website that answers most common aircon questions.
Post by: sophos9 on 25 August 2008, 20:12:39
Thanks for the tip however all these mobiles dont cover my area... (I'm in deliverance country  :y )
Post by: alexandjen on 25 August 2008, 22:49:08
Post by: lpgelite on 25 August 2008, 23:36:19
Hmmmm,  tricky one this..
If your air con is just a bit tired but otherwise OK then there's very little Kwikfit can do to 'dangle berries' it up.
I had this decision to make with a Volvo. The a/c worked OK but not brilliant, so I deduced that it was not leaking due to the fact that there seemed to be sufficient gas to enable the compressor to run correctly.
I just felt it needed freshening up as there was no record of it ever having been vac'd out and recharged, as is considered good practice every three years or so.
Even the most simeon of fitters is able to hook up the machine, type in the vehicle details and leave it to do its own thing for an hour or so, which is as involved as it's necessary to get from their point of view.
You even get a print out of what's been recovered, how long and deep it's been held under vacuum and what new stuff has been put in.
The machine literally does it all on its own.
I wouldn't normally go to one of these places, but the Volvo's been fine ever since and I even blagged a deal on a couple of premium tyres while I was there. Got 'em fitted & balanced for same make / price as I could find mail order off t'internet or eBay...
They don't seem to try their tricks if you come across as a bit savvy, and not all their depots deserve the reputation the company's earned itself. Some are definitely and infinitely better than others.
Speaking as I found, I'd tread carefully but Carlisle was fine and I'd go there again if necessary.
Post by: Albert1 on 26 August 2008, 10:47:25
Their FAQ section makes for hilarious reading: Q - How often should I run the air conditioning system in my car?  Their answer: "Ideally, all the time. It is false economy to turn the system off in the winter"
We've all heard that you should run the a/c at least every 2 weeks, even in winter, but all the time?  Pull the other one...
Post by: mark.adams on 26 August 2008, 19:26:34
Aah you mean E.Anglia   ;D ;D ;D ;D
Post by: sophos9 on 26 August 2008, 19:42:34
Darn right.. *hick*
Had a ring around, spoke to Kwik fit and started to quiz them a bit, asked if they vacuum and how long it will take and they could not answer, they kept saying that they pressure test... erm case closed!
Spoke to another company that knew plenty but cost £88 then spoke to a specialist who charges £50 for a full service and adds UV, vacuums, tests etc before doing anything - will have a punt there!!
Post by: dbug on 26 August 2008, 22:45:44
Yes there is  ;)
