Omega Help Area => Omega General Help => Topic started by: dbug on 28 August 2008, 15:00:36
Is there a guide to cleaning a V6 ICV, can't see one in maintenance section.
OK - can anyone give me some pointers on cleaning V6 ICV?
Remove it and spray it liberaly with carb cleaner.....I then use a small paint brush to get it mega clean.
Rinse out with more carb cleaner and then lube with a light oil or lubricant
As simple as that - thanks Mark.
Done it - it was well stuck up. Once i got plenty of carb cleaner in there it freed up & i could see how it works! Dried it out, oiled it (3in1) and refitted.
Will see next time I use car if it still stalls when slowing right down like going into a roundabout (when traffic coming - don't slow down if its clear ;)).
Checked codes - 19 not reappeared since new Vx crank sensor put on yesterday. No signs of the 57 & 165 i got after I cleared the 19 prior to changing crank sensor.
