Omega Help Area => Omega General Help => Topic started by: robby30 on 27 August 2008, 20:41:54
Title: Brakes, who knows where im going!
Post by: robby30 on 27 August 2008, 20:41:54
evening all
I have a bit of a problem with the brakes on the omega, when braking lightly the car is pulling right, i have done just about everything i can think of to cure it. All the brakes have been off the car, pads checked and almost new discs fine. calipers removed cleaned and seem to be in order. new braided hoses for the fronts no airlocks, new fluid...
so whats up?!
i think it might just be missing its mechanic ;D
Title: Re: Brakes, who knows where im going!
Post by: feeutfo on 27 August 2008, 20:54:32
could be a number of things but if you confident the brakes are working well and the sliders are not seized on the pulling side, the next place to look has got to be wishbone bushes. Have a search, its all there. Play in the lower suspension arm bush deflecting the wheel off line on the brakes and pulling the car off course, if your driving at 11 or 1
o clock on the s. wheel and constantly correcting the stearing most likely its the bushes. But if so, one is alot worse that the other, from what you said. They "usually" go at a comparable rate/pass side being worsed if anything. In my experience anyway. Hope helps.
Post by: FRE07962128 on 27 August 2008, 20:55:58
evening all
so whats up?!
Sorry to ask a simple question first, but have you checked your tyre pressures especially on the front? :-/ :-/ :-/
Post by: robby30 on 27 August 2008, 20:57:40
evening all
so whats up?!
 :) all at 32psi but simple often works!
Post by: Lazydocker on 27 August 2008, 20:57:52
G call as per usual Lizzie...
But my money's on the wishbones!! :y :y
Post by: robby30 on 27 August 2008, 21:00:15
they dont look very worn only replaced them 9 months ago give or take but i will have a look
any other ideas?
Post by: Lazydocker on 27 August 2008, 21:05:40
Steering Idler???? :-/ :-/
Post by: robby30 on 27 August 2008, 21:14:35
also new vx part last autumn, the car drives straight and true when not braking, dont think its that
Post by: FRE07962128 on 27 August 2008, 21:17:49
Looks as though you could be right, or is it something else to do with the suspension?! :-/
Another "simple" thought; could it be loose wheel nuts? :-/ :-/
Post by: feeutfo on 27 August 2008, 21:18:42
caliper slider seized?
Post by: FRE07962128 on 27 August 2008, 21:20:40
evening all
so whats up?!
Another one for you;  is it possible you allowed air into the new brake fluid, or have left the nipple bleed nut slightly open?? :-/ :-/
Post by: Lazydocker on 27 August 2008, 21:21:48
evening all
so whats up?!
Yet another good call... Easy to do!!!
Post by: robby30 on 27 August 2008, 21:23:44
all looks ok moving freely. i think i will have to swap parts with a known good one
i wonder if FYS will notice :D
Post by: Dazzler on 27 August 2008, 21:25:50
Could be geometry is out, which is showing up more so under braking :-/
Post by: FRE07962128 on 27 August 2008, 21:27:57
evening all
so whats up?!
Thanks again!  :y :y
It is just I have found it is often the "simple" things you should check out before suspecting more major components of a car. :D ;)
Post by: robby30 on 27 August 2008, 21:28:07
evening all
so whats up?!
no dont think so ! and all closed tightly.
and it was doing all this before i started to mess about blindly!
Post by: feeutfo on 27 August 2008, 21:35:15
when did it start? In relation to the work done you mentioned i mean, did it just gradually start and got worse? Or did it arrive one day all of a sudden? Struggling now tbh.
Post by: Omegatoy on 27 August 2008, 21:37:17
rear donut bushes shot will allow it to pull ander braking but camber on front will also effect it,
Post by: FRE07962128 on 27 August 2008, 21:37:22
I am starting to suspect of faulty brake slave cylinder on the offending wheel. :-/
Post by: robby30 on 27 August 2008, 21:49:28
problem started suddenly on trip to france work carried out has been carried out over the last few weekends etc.
if it helps it stops quite straight if i stamp on the anchors
Post by: Omegatoy on 27 August 2008, 21:54:58
hmm that does suggest a sticking or lazy caliper then
Post by: dbug on 27 August 2008, 21:55:49
Were your recent discs Vx or pattern - if pattern could be discs, even after low mileage!  Are slides on calliper free on side that is pulling?
If above all ok - wishbones or steering idler?
Post by: FYS on 27 August 2008, 22:15:44
Some great advice here Robby!
Do Omegas have a brake slave cylinder on each wheel????
I thought it went pedel, servo, master cylinder, brake hoses, caliper, pads, disc....  may have missed something there....
Anyway, all the usual suspects I think you have checked, or recently changed - you can try my calipers if you want....
FYS.
Post by: FRE07962128 on 27 August 2008, 23:32:39
FYS.
Yes sorry I still refer to them as that, but of course they are the calipers of todays disc braked cars! ;D ;D ;)
Post by: feeutfo on 27 August 2008, 23:44:37
Yeah, sorry but i am going to bet on wishbones, only a pound mind. Esp. If you have checked the brakes as thoroughly as you say. What procedure did you follow when torquing up the wishbones?
Post by: Pete Elite on 28 August 2008, 18:33:35
  Hi, Have you checked the springs not broken on that side?
