Omega Help Area => Omega General Help => Topic started by: stemon on 30 August 2008, 18:27:51
hi guys i need to tow a omega auto with the ar35 box , whats the max speed i can tow and how many miles? i will be using a a-frame and its about 250miles :-/
Disconect the prop :y
disconnect the prop shaft for that distance. Otherwise bye-bye gearbox.
Then its the standard limit for towing which i believe is 65mph on the motorway. same as pikey wagons
thanks guys never thought of disconnecting the prop ;D good thinking.
And the towing speed is 60 :y :y :y
50mph for 50 miles is recommended max...disconnect prop shaft 3 bolts and you can tow as fast as you like for as long as you like :)
Or...tow with engine of the car your towing running too...
Or...tow for the 50 miles, start the engine to get fluid in the box for a bit then tow another 50 miles and so on lol
